2 Replies Latest reply on Jan 14, 2010 8:18 PM by Alejandro67
    Print Flash Art in VECTORIAL MODE without BLANKS arround objects
    Alejandro67
           Dear Sirs, I need to solve this problem since 6 months ago, I nee
      d help from an expert to get a success, I have an flash aplication it receives by xml information for 4 movie clips to load movies into screen when it is ok, the screen is printing, the pictures into Movie clips have a good quality resolution to print a big sizes over letter size, double, triple or cuadruple of letter size, with high quality, the only way is vectorial print but it always show blanks arround the objects, I need to solve this problem to print big sizes of these screens.
      Some one has an idea to help me with that in flash or can recommend any kind of solution to this problem
      Thanks gurus for your time
      Kind regards
      Alejandro Bazan G.
      abazangatti@gmail.com
        • 1. Re: Print Flash Art in VECTORIAL MODE without BLANKS arround objects
          waterdad568 Level 3
          I going to presume two thing based on your description.
          1. Your using .png vector images with a transparent background.
          2. Your using IE 6 or earlier.
          If those are indeed the case, you should do one of two things.
          1. Update your browser to the latest version.
          or
          2. Use a javascript workaround for the .png rendering in IE.
          • 2. Re: Print Flash Art in VECTORIAL MODE without BLANKS arround objects
            Alejandro67 Level 1
            Dear Waterdad568:
            I can explain better my last explanation.
            1.- yes I'm using a png vector images
            2.- I'm using last versions of explorer or others Internet browsers
            The really work of this SWF is to make a poster with 4 movie clips and 4 text fields where they receive the info from XML files, dynamically reading all info from a data base,
            The printer job read the poster from the screen and  print to scale the problem is when I try to print in vectorial mode because the png files show the transparent background like blanks, and I need quality to print in big sizes the poster, sizes over A4 like A3 and bigger.
            Awaiting your kindly reply
            Best Regards
            Alejandro Bazan G.
            General Manager
            Web Conection S.A.C.
            abazan@webconection.net
            Nextel 518262865 Cellphone: 511-998262865
