4 Replies Latest reply on Jan 14, 2010 6:11 PM by 345hi
    flash cs3 newbie help - setting up a clicktag
      I am just about to pull my hair out - please help as I don't have that much hair to pull out.
      I created a flash file in Flash CS3 and was told I need to add a click tag for an agency who want to keep track of the click throughs for the ad.
      I have created the invisible button layer and set up the 'hit' and tried and tried and tried to select the button and add some action script to it.
      (which I have seen three different codes to use)
      Each time I export it or publish it I get the error message: mouse events are permitted only for button insances on release. I have read and understand I need to assign the code to the button and not the frame but for the life of me, I cannot figure out how to do that.
      I select the button (which I have converted to a 'button') and F9 or left click to get the Actions panel and once I am there and try to use the '+' to add code, it automatically shows 'Current Select/Frame 1 in the left side of the Actions panel. I get that it is adding the code to the frame but how do I get it to add the code to the button???
      So my question is 1) how do I add the code to the button and not the frame and 2) what code should I use?
      Any and all help is GREATLY appreaciated!
      oops...forgot to add I am using AS2. Thanks!
