2 Replies Latest reply on Jan 15, 2010 7:15 AM by dwelford
    Flash Builder 4 - Web Services
    dwelford
      I am using the Flash 4 beta to connect to web services, my connections are fine and everything works as it should.
      I added a call to the web services on a button Click event and noticed I need to somehow wait for the response back from the web services before continue with the click event. How do I wait for the result back from the web services call in a button click event?
      David................
        • 1. Re: Flash Builder 4 - Web Services
          Sameer Bhatt Adobe Employee
          Are you doing something like this -
          protected function button_clickHandler(event:MouseEvent):void
                  webService.operation1();
                  .....some code here......
          So, as the calls are aynchronous, you'll not get the response just after calling the operation.
          You need to wait for the result from the operation call and do things after the result has come, something like -
          private var operationResult:CallResponder = new CallResponder();
                  operationResult.addEventListener(ResultEvent.RESULT,resultHandler);
                  operationResult.token = webService.operation1();
          protected function resultHandler(event:ResultEvent):void
                  // result can be accessed through operationResult.lastResult or event.result
          • 2. Re: Flash Builder 4 - Web Services
            dwelford Level 1
            That worked perfect.
            david................
