10 Replies Latest reply on Jan 21, 2010 8:53 AM by dmutantz
    how can I get my netconnection.nearID?
    suxuekun
      I build my first application like this to connec to stratus;
      myapp.xmxl
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="connect()">
      <mx:Script source="myapp.as"/>
      </mx:Application>
      myapp.as
      // ActionScript file
      import flash.events.NetStatusEvent;
      import flash.net.NetConnection;
      import flash.net.NetStream;
      import mx.controls.Alert;;
      private const StratusAddress:String = "rtmfp://stratus.adobe.com";
      private const DeveloperKey:String = "my developerKey";
      private var nc:NetConnection;
      private var sendStream:NetStream;
      private var recvStream:NetStream;
      private function connect():void
      nc = new NetConnection();
      nc.addEventListener(NetStatusEvent.NET_STATUS,netConnectionHandler);
      nc.connect(StratusAddress + "/" + DeveloperKey);
      private function netConnectionHandler(event:NetStatusEvent):void
      Alert.show(event.info.code);
      Alert.show(nc.nearID);
      I got the message
      NetConnection.Connect.Success
      at this line ~~Alert.show(event.info.code);
      but I can't get nc.nearID;
      is there something wrong in my code ? or what should I do to get my nc.nearID?
        • 1. Re: how can I get my netconnection.nearID?
          suxuekun Level 1
          is there anyone can help me?
          is there something wrong with my code?
          how can I get the peerID from stratus?
          • 2. Re: how can I get my netconnection.nearID?
            Michael Thornburgh Adobe Employee
            i don't see anything outwardly wrong with your code.  do you get some kind of exception when you access NetConnection.nearID?  did you remember to set your project to target Flash Player 10 when you build it, so that the nearID property is visible?
            -mike
            • 3. Re: how can I get my netconnection.nearID?
              suxuekun Level 1
              thank you for your help mike.But I think I have did it.
              flex builder 3
              3.2.0 sdk
              flex-config.xml
              I have changed lines below
              <target-player>10.0.0</target-player>
              <external-library-path>
                        <path-element>libs/player/10/playerglobal.swc</path-element>
                    </external-library-path>
                    <library-path>
                       <path-element>libs</path-element>
                 <!-- keep the original location in the libpath for backwards-compatibility -->
                       <path-element>libs/player</path-element>
                       <path-element>libs/player/10</path-element>
                    <path-element>locale/{locale}</path-element>
                    </library-path>
              I think that's all to do for Flash Player 10 ver.
              anything I missed?
              if it's not for FP10.  it should tell me that nc.nearID is not defined or something else ,because 9ver doesn't have nc.nearID.
              in fact after that code I have
              sendStream = new NetStream(nc,NetStream.DIRECT_CONNECTIONS);
              sendStream.addEventListener(NetStatusEvent.NET_STATUS,netStreamHandler);
              and something like
              private function getconnect(id:String):void
              recvStream = new NetStream(nc,id);
              recvStream.addEventListener(NetStatusEvent.NET_STATUS, netStreamHandler);
              if it's not for 10 ver . it should tell me that there are some problems. because netStream(NetConnection,peerID) only have one parameter in FP9
              but it runs successfully without any problem except I can't get nc.nearID. so I think I have set my project to target Flash Player 10 .
              • 4. Re: how can I get my netconnection.nearID?
                ok, so you are clearly targeting the correct version of Flash Player.  now the question is: when you try to access NetConnection.nearID, what *are* you getting?  an exception?  a blank?  is your failure simply that a second flex Alert box isn't showing up?  or is it showing up but it's empty?
                • 5. Re: how can I get my netconnection.nearID?
                  suxuekun Level 1
                  It doesn't show up.
                  I get nothing.
                  sample
                  Alert.show(event.info.code)//netConnection.Connect.success  --- now here it's ok
                  Alert.show(nc.nearID)//nothing just nothing ,not empty   --- it stoped here,I think
                  Alert.show("hello,hello")//nothing --- can't reach here.
                  • 6. Re: how can I get my netconnection.nearID?
                    perhaps Flex SDK 3.2.0 doesn't let you stack two alert boxes on top of each other.  i was able to stack them with SDK 3.4.0.  if you're not getting the second box, then one of two situations must be occurring: NetConnection.nearID is throwing an exception so you never get to create the Alert box, or the Alert box just isn't being displayed but there's no actual problem accessing NetConnection.nearID.
                    i recommend either only popping one Alert box up (perhaps combine the event code and the nearID into one string?) or use some other way of communicating the nearID to the user.  perhaps a Flex text field or something that you set, or a String variable that you've bound with a text field and then set the variable to the nearID.
                    • 7. Re: how can I get my netconnection.nearID?
                      suxuekun Level 1
                      1 Alert
                      Alert.show("1");
                      Alert.show("2");
                      it's ok.
                      once I did a stupid thing like this
                      timer = new Timer(10);
                      timer.addEventListener(TimerEvent.TIMER,onTimer);
                      timer.start();
                      private function onTimer(event:TimerEvent):void
                              Alert.show(timer.currentcount);
                      /// er .so , it's not this problem
                      And I also has this app download from adobe
                      videophonelab
                      and it has
                      status("Connected, my ID: " + netConnection.nearID + "\n");
                         private function status(msg:String):void
                          statusArea.text += msg;
                          statusArea.validateNow();
                          statusArea.verticalScrollPosition = statusArea.textHeight;
                          trace("ScriptDebug: " + msg);
                      I also get nothing on the textarea;
                      so I think it's just something wrong that the peerID isn't returned.......
                      • 8. Re: how can I get my netconnection.nearID?
                        i took your code as originally posted and copy-pasted it into a new Flex project (separate .mxml and .as).  the only changes i made were 1) i used my default Flex SDK (3.4.0-9271 MPL) and 2) i substituted my own Stratus developer key for "my developerKey" in your code.  i then changed the compiler "require Flash version" to 10.0.0 and ran it in my browser (with Flash Player 10,0,42,34).  i got two alert boxes, one with my nearID and one with "NetConnection.Connect.Success".
                        since you say execution of your netConnectionHandler function stops after dispatching the first Alert box, and you later indicate that you don't dispatch a third Alert box after trying to access nc.nearID, the only conclusion is that trying to access nc.nearID is raising an exception.
                        once you have *double checked* that you are running this in Flash Player 10.0 or above, the next step is to determine what exception you are getting.  you can wrap your access of nc.nearID in a try/catch block and if it raises an exception, print out what the exception is.  you could also install a debug Flash Player, which should print out the exception in a dialog box.  even better would be to run the app in the Flex Builder debugger.
                        -mike
                        • 9. Re: how can I get my netconnection.nearID?
                          suxuekun Level 1
                          I find what's wrong with it......
                          I forgot to change the compiler ~!~|||
                          now it's ok......
                          so it's built on 10 but run in 9.
                          I think I should use sillyboy as my ID
                          • 10. Re: how can I get my netconnection.nearID?
                            dmutantz
                            Hi
                            Thanks for the tip , this was also driving me crazy I could get evrything but nearID.  This has saved me lots of time , great question , great answer.
