4 Replies Latest reply on Jan 15, 2010 7:06 AM by Wade_Zimmerman
    Illustrator CS4 on a 64-bit XP OS
    Andrew.Nelson Level 1
      I tried loading Illustrator on my machine at work, but when I did, the computer essentially came to a stop.  I had to wipe my hard drive and reinstall everything.  Is there a way that I can make the SW work on this machine?
      Andrew
        • 1. Re: Illustrator CS4 on a 64-bit XP OS
          Wade_Zimmerman Level 6
          I believe you have to run it a a 32 bit application or it is no dice how you do that I do not know but I believe there is a way to install and run as a 32 bit only application. but it cannot be run asa 64 bit since it is not.
          I am wrong about this it is not certified for XP 64 but it seems others do use it
          • 2. Re: Illustrator CS4 on a 64-bit XP OS
            What exactly did you do? What machine is it? While XP64 is not officially supported, CS4 should run just fine on it. It does on my machine here at work...
            Mylenium
            • 3. Re: Illustrator CS4 on a 64-bit XP OS
              The Machine is a Dell Precision M6400
              Win XP
              Professional x64 Edition
              Vers. 2003
              Serv Pack 2
              The computer is a:
              Intel Core 2 Extreme
              CPU Q9300 @ 2.53 GHz
              2.53 GHz, 7.98 GB of RAM
              When I first received the computer, I installed SolidWorks 2009, Photoshop.  Everything worked fine.  I then installed Illustrator, and the machine crashed.  I had to have the IT Dep. re-image the system.  I searched and could not find a 64bit version of Illustrator, so I did not install it.  Than BAD part is that we paid for the license, and cannot use it.
              Andrew Nelson
              Industrial Designer
              Direct +1 469.229.2185
              Creating value that increases customer competitiveness
              P Recycling one aluminum can saves enough energy to run a TV for three hours.
              • 4. Re: Illustrator CS4 on a 64-bit XP OS
                I think it should work since you installed a new system.
