13 Replies Latest reply on Jan 15, 2010 2:02 PM by kglad
    Having issues applying classes to my textfield.
    baianomauricioct
      Hi all, good morning. I can't express good enough how this forum has been so great to me. I am learning SO MUCH the actionscript. Anyways, my problem now refers to the css. I have a quotes.css already been loaded into the flash, how can I apply a class to a textfield, the code is below but it's now working properly.
      Anyone might be kind enough to help?
      Thanks.
      var tl:MovieClip = this;
      var colnum:Number = 2;
      var xSpace:Number = 200;
      var ySpace:Number = eval("column"+i);
      for (var i = 1; i<=30; i++) {
          tl.createTextField("column"+i,tl.getNextHighestDepth(),xSpace*((i-1)/colnum),ySpace,200,3 0);
          tl["column"+i].html = true;
      tl.createTextField("resultsField",tl.getNextHighestDepth(),xSpace,ySpace*Math.floor(i+coln um/colnum),200,30);
      resultsField.html = true;
      this.createTextField("moeda",this.getNextHighestDepth(),325,80,200,30);
      var my_xml = new XML();
      var stylish = new TextField.StyleSheet();
      stylish.load("quotes.css");
      stylish.onLoad = function(success:Boolean) {
          if (success) {
                     trace("cssLoaded!");
              tl["column"+i].styleSheet = stylish;
              my_xml.onLoad = function(yeah:Boolean) {
                  if (yeah) {
                      var a:Array = [];
                          RootNode = my_xml.firstChild;
                          eval("column"+i).htmlText = "<p class='regular'>"+RootNode.childNodes[i].firstChild+"</p>";
                          a.push(Number(stripF(tl["column"+i].text)));
                          moeda.htmlText = stripF(RootNode.childNodes[0].firstChild.nodeValue);
                          //trace(column10._y);
                          //trace(column20._x);
                          trace(resultsField.text);
                          trace(stripF(RootNode.childNodes[0].firstChild.nodeValue));
                      resultsField.htmlText = minF(a);
                  } else {
                      trace("buahCol!");
              my_xml.ignoreWhite = true;
              my_xml.load("quotes.xml");
      function minF(a:Array):Number {
          var min:Number = a[0];
          for (var i:Number = 1; i>a.length; i++) {
              if (a[i]<min) {
                  min = a[i];
              } else {
                  trace("buahMin!");
          return min;
      function stripF(s:String):String {
          return s.split(" ").join("").split("\n").join("").split("\r").join("");
        • 1. Re: Having issues applying classes to my textfield.
          use:
              tl.createTextField("column"+i,tl.getNextHighestDepth(),xSpace*((i-1)/colnum),yS pace,200,30);
          tl.createTextField("resultsField",tl.getNextHighestDepth(),xSpace,ySpace*Math.fl oor(i+colnum/colnum),200,30);
              if (success) {
                      if (yeah) {
                          var a:Array = [];
                              eval("column"+i).htmlText = "<p class='regular'>"+stripF(RootNode.childNodes[i].firstChild)+"</p>";
                      } else {
                          trace("buahCol!");
                  if (a[i]<min) {
                      min = a[i];
                  } else {
                      trace("buahMin!");
              return min;
          • 2. Re: Having issues applying classes to my textfield.
            baianomauricioct Level 1
            Sorry, but it didn't work.
            • 3. Re: Having issues applying classes to my textfield.
              this is what I have in my css file:
              .regular {
                font-family: Arial,Helvetica,sans-serif;
                font-size: 24px;
                color: #FF0000;
              • 4. Re: Having issues applying classes to my textfield.
                Funny, because it won't work even if I input this
                            eval("column"+i).htmlText = "<p style='font-size:30px'>"+RootNode.childNodes[i].firstChild+"</p>";
                • 5. Re: Having issues applying classes to my textfield.
                  are your textfields html enabled?
                  • 6. Re: Having issues applying classes to my textfield.
                    yes, they are:
                    • 7. Re: Having issues applying classes to my textfield.
                      try it without specifying a font-family.
                      • 8. Re: Having issues applying classes to my textfield.
                        no dice!
                        it didn't work out.
                        • 9. Re: Having issues applying classes to my textfield.
                          zip your css, xml and fla and attach to this forum.
                          • 11. Re: Having issues applying classes to my textfield.
                            you're not assigning the styleSheet property to your textfields.  use:
                            kglad wrote:
                            use:
                                if (success) {
                                        if (yeah) {
                                            var a:Array = [];
                                                eval("column"+i).htmlText = "<p class='regular'>"+stripF(RootNode.childNodes[i].firstChild.nodeValue)+"</p>";
                                        } else {
                                            trace("buahCol!");
                                    if (a[i]<min) {
                                        min = a[i];
                                    } else {
                                        trace("buahMin!");
                                return min;
