4 Replies Latest reply on Jan 15, 2010 2:21 PM by TechComp
    Changing mxml UIComponents with Actionscript
    TechComp
      Hello,
      i´m searching about a way to change the text of labels createtd with Designer by Actionscript. But i try to browse the entire collection to find all used UI-Components.
      If i use the debugger, i can see  an mxmlContent Array with all Components but i can´t use theses in Actionscript.
      Regards
      Thomas
        • 1. Re: Changing mxml UIComponents with Actionscript
          David_F57 Level 5
          In designview give your component an ID  for instance  if its a label for surname call it lblSurname.
          in actionscript  you then assign a value to the labels text  -  lblSurname.text="mySurname";
          David.
          • 2. Re: Changing mxml UIComponents with Actionscript
            TechComp Level 1
            Hi David,
            thanks for the reply, but that is not, what i want.
            I´m searching about a solution to browse the complete mxml component list in Actionscript.
            We will change the labels of all items by runtime with data from a cfc (Coldfusion component) without hard coding the labels in Actionscript. I need a readable collection of all UI-Components to read the id´s, comparinge these with the cfc datasource and change these with other data from this source.
            As i say, the Applipcation.mxmlContent (or any Group.mxmlContent) has all these properties. Baut i can´t use mxmlContent in Flashbuilder because i got an error, that this property is not defined instead i can read that in the debugger.
            Thomas
            • 3. Re: Changing mxml UIComponents with Actionscript
              rfrishbe Level 3
              I'm a little confused about exactly what you want, but you can get a list of all the children in a component by asking for numElements and using
              getElementAt(index).  You can push that in to an Array or an ArrayCollection or wherever you want.
              -Ryan
              • 4. Re: Changing mxml UIComponents with Actionscript
                TechComp Level 1
                Ryan,
                sorry about my bad english. It´s very difficult for me to explain exactly what i want.
                But your answer was exactly the hint i needed.
                Thomas
