0 Replies Latest reply on Jan 15, 2010 6:48 AM by Carol L. Frampton
    [svn:fx-4.0.0] 13523: TLB Build  590.
    Carol L. Frampton Level 2
      Revision: 13523
      Revision: 13523
      Author:   cframpto@adobe.com
      Date:     2010-01-15 06:48:11 -0800 (Fri, 15 Jan 2010)
      Log Message:
      TLB Build  590.  Approved for checkin.
      Build 590
      • Fix 2525017 - added range checking to IMEClient getTextBounds to avoid exceptions caused by invalid ranges.  Returns empty rectangle in bad range case.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/air-config.xml
          flex/sdk/branches/4.0.0/frameworks/flex-config.xml
          flex/sdk/branches/4.0.0/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayo ut.xml
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClie nt.as
          flex/sdk/branches/4.0.0/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.590.swf
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/rsls/textLayout_1.0.0.589.swf
