8 Replies Latest reply on Jan 15, 2010 2:14 PM by JR "Bob" Dobbs-qSBHQ2
    using a radio button in cfmail / form.
    cfsetNewbie Level 1
      Hello;
      This is a silly question, but I can't remember how to program in radio buttons for a cfmailer. I have 3 radio buttons, basically, I just need to know what the users choice was when they checked it off. The following is my radio buttons and what I have for code right now. But I'm not grabbing the proper variable, I also tried dumping a few diffrerent variables to see if I could get it.
      <input name="type" type="radio" onClick="setVisibility('sub3', 'inline');setVisibility('sub4','none');setVisibility('sub5','none');" value='male' checked="checked"/>Magnets
      <input type="radio" name="type" value='female' onClick="setVisibility('sub3', 'none');setVisibility('sub4','inline');setVisibility('sub5', 'none');"/>Paper Steel
      <input type="radio" name="type" value='child' onClick="setVisibility('sub3', 'none');setVisibility('sub4','none');setVisibility('sub5', 'inline');"/> both
      on my response page, I tried this:
      <cfif form.type EQ "male">
      if this was their choice, then this set of rules would apply
      </cfif>
      and so on for the other two choices. This isn't catching my buttons, what am I doing wrong? do I need to make a paramiter for the radio buttons before I can allow it to function? like this?
      <cfparam name="FORM.type" default="">
      then I can use my if statement? (that isn't working right now either)
      here is what I'm trying to dump:
      <cfdump var="#form.type#">
      <cfabort>
      </cfdump>
      How do I do this? Can anyone help me?
        • 1. Re: using a radio button in cfmail / form.
          BKBK Adobe Community Professional & MVP
          Make sure you specify the form's action and method, for example,
          <form action="path_to_responsePage.cfm" method="post">
          • 2. Re: using a radio button in cfmail / form.
            cfsetNewbie Level 1
            I have all that. I was just posting the code for the radio bu
            ttons.
            my if statement isn't catching them. can you help me on that? What variables am I supposed to go after?
            • 3. Re: using a radio button in cfmail / form.
              Replace single quotes by double quotes. Change <input ... value='male' ...>, <input ... value='female' ...>, etc., to <input ... value="male" ...>, <input ... value="female" ...>, ... respectively.
              • 4. Re: using a radio button in cfmail / form.
                cfsetNewbie Level 1
                lol, I just tried fixing all that, and
                even added an id field. I think it's my "if" statement now.
                <cfif form.type EQ ('male')>
                you get this
                </cfif>
                <cfif form.type EQ ('female')>
                you get this
                </cfif>
                <cfif form.type EQ ('child')>
                you get this
                </cfif>
                am I going after this wrong? I know a radio button is treated as a yes/no type input. I also know i can use it like this and still have it work.
                • 5. Re: using a radio button in cfmail / form.
                  JR "Bob" Dobbs-qSBHQ2 Level 3
                  I suspect that you have a problem in some portion of your code that you have not posted. To help debugging I suggest you create a simple test using two pages: input.cfm and action.cfm.  Get the most simple case working then add the javascript, css, and CF code to make your application work.
                  <!--- contents of input.cfm --->
                  <html>
                  <head>
                       <title>Input</title>
                  </head>
                  <body>
                       <form action="action.cfm" method="POST">
                            Choose type: <br />
                            <input name="type" type="radio" value="male" />     Male<br />
                            <input name="type" type="radio" value="female" /> Female<br />
                            <input type="submit" />
                       </form>
                  </body>
                  </html>
                  <!--- content of action.cfm --->
                  <html>
                  <head>
                       <title>Action</title>
                  </head>
                  <body>
                       <cfif form.type eq "male">
                            Type is male.
                       <cfelseif form.type eq "female">
                            Type is female.
                       </cfif>
                       Here is a cfdump of the form variables:<br />
                       <cfdump var="#form#" />
                  </body>
                  </html>
                  Message was edited by: JR "Bob" Dobbs Added sample for action.cfm
                  • 6. Re: using a radio button in cfmail / form.
                    you get this
                    </cfif>
                    you get this
                    </cfif>
                    you get this
                    </cfif>
                    It should be without the brackets. What happens when you drop the brackets, like this
                    <cfif form.type EQ 'male'>
                    you get this
                    </cfif>
                    <cfif form.type EQ 'female'>
                    you get this
                    </cfif>
                    <cfif form.type EQ 'child'>
                    you get this
                    </cfif>
                    What happens when you omit the onClick attribute, and experiment with
                    <cfinput type="radio" name="type" value="male">
                    <cfinput type="radio" name="type" value="female">
                    <cfinput type="radio" name="type" value="child">
                    • 7. Re: using a radio button in cfmail / form.
                      cfsetNewbie Level 1
                      I figured it out. It's because I'm using this as my submit button:
                      <cfinput type="image" name="Submit" validateat="onSubmit" validate="submitonce" style="cursor:Hand;" title="Submit Form" onMouseDown="javascript:this.src='img/submit.gif';" onMouseOver="javascript:this.src='img/submitOver.gif';" onMouseOut="javascript:this.src='img/submit.gif';" value="contact" src="img/submit.gif" alt="Contact Us" width="120" height="20"  border="0">
                      It doesn't like the image submit button.
                      So looks like this is out... unless someone knows a better way to get it to work using it. I couldn't even get the form to dump with this in. once I put in a real submit button, it all works.
                      thanks for the help
                      • 8. Re: using a radio button in cfmail / form.
                        cfsetNewbie,
                        Does the cfinput of type="image" render an HTML input type="button" tag or a input type="submit" tag in the browser?
