0 Replies Latest reply on Jan 15, 2010 12:51 PM by Paul Reilly
    [svn:fx-4.0.0] 13531: * Fixed invalid property reference error reporting by postponing the
    Paul Reilly Level 1
      Revision: 13531
      Revision: 13531
      Author:   preilly@adobe.com
      Date:     2010-01-15 12:50:59 -0800 (Fri, 15 Jan 2010)
      Log Message:
      • Fixed invalid property reference error reporting by postponing the
        validation until prelink when the MxmlDocument's type is available.
      QE notes:
      Doc notes:
      Bugs: SDK-22995, SDK-24738
      Reviewer: Gaurav, Darrell
      Tests run: checkintests, mxmlcunit
      Is noteworthy for integration: no
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler_en.properties
          Renamed css.StyleDef.InvalidPropertyReference to
          css.StylesContainer.InvalidPropertyReference.
        modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          Removed InvalidPropertyReference checking from processReference().
        modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          Modified setMxmlDocument() to store a reference to it's QName.
          Modified validate() to iterate over all style properties and to
          call validatePropertyReferences() if mxmlDocumentQName is not
          null.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22995
          http://bugs.adobe.com/jira/browse/SDK-24738
      Modified Paths:
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler_en.properties
