0 Replies Latest reply on Jan 15, 2010 2:45 PM by GordonSmith
    [svn:fx-4.0.0] 13535: Part 1 of fixing line endings in AS and MXML files so that line numbers are correct while debugging .
    GordonSmith Level 4
      Revision: 13535
      Revision: 13535
      Author:   gosmith@adobe.com
      Date:     2010-01-15 14:45:38 -0800 (Fri, 15 Jan 2010)
      Log Message:
      Part 1 of fixing line endings in AS and MXML files so that line numbers are correct while debugging.
      We've got a widespread problem with line-endings (\r\n vs \n vs \r) because not all our files have svn:eol-style set to "native". (With this setting, the line endings are adjusted for the platform that you check out code onto. Without it, you can end up with all-Mac line endings on a Windows machine, WindowsMacUnix line endings on a Mac, etc. The goal is all-Win on Win, all-Mac on Mac, etc.)
      For schedule reasons, we've decided to minimize risk by fixing only AS and MXML files in frameworks/projects that contribute to our SWCs, because here line-ending problems can throw off line numbers and the debugger doesn't step through the right lines of code.
      You can't set svn:eol-style to "native" unless the line endings are already correct for your platform. Since I'm on Windows, I wrote a script to find a fix the files that had any \n or \n line endings. The files now have \r\n.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24966
      Reviewer: Pete
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24966
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/IDeferredContentOwner.a s
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/ISelectableList.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/core/LayoutElementUIComponen tUtils.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/geom/TransformOffsets.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/skins/halo/WindowBackground. as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/branches/4.0.0/frameworks/projects/framework/src/mx/utils/OnDemandEventDispatche r.as
          flex/sdk/branches/4.0.0/frameworks/projects/osmf/src/org/osmf/media/MediaFactory.as
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/src/mx/rpc/http/HTTPMultiService.as
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/src/mx/rpc/http/Operation.as
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/src/mx/rpc/http/mxml/HTTPMultiService.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/HSlider.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/mediaClasses/Volum eBar.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/supportClasses/Dro pDownController.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/supportClasses/Dro pDownListBase.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/supportClasses/Scr ollerLayout.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/components/supportClasses/Sli derBase.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/effects/supportClasses/Animat eTransformInstance.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/effects/supportClasses/MoveIn stance.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/events/SkinPartEvent.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/skins/spark/HighlightBitmapCa ptureSkin.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/skins/spark/ScrollerSkin.mxml
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/styles/metadata/AdvancedInher itingTextStyles.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/styles/metadata/AdvancedNonIn heritingTextStyles.as
          flex/sdk/branches/4.0.0/frameworks/projects/spark/src/spark/utils/LabelUtil.as
          flex/sdk/branches/4.0.0/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericSt epperTextInputSkin.mxml
