4 Replies Latest reply on Jan 15, 2010 9:50 PM by Kodebuster
    Blurry Video after Burn
    PeterHlu
      I am using Premiere Elements 8.0.  After I burn my project onto either a disc or file folder the resulting quality of the video is blurry when there is movement on the video.  If I view the video in the project, the quality is fine.  Has anyone run into this issue?  Any help is appreciated.
        • 1. Re: Blurry Video after Burn
          the_wine_snob Level 9
          Please tell us what your source footage is. Compressed footage, such as MPEG-2 can look pretty good in PrE, but when it is re-Transcoded to MPEG-2 for DVD-Video, that second compression can really show issues with motion, either camera movement, or subject movement.
          • 2. Re: Blurry Video after Burn
            PeterHlu Level 1
            Thanks for the quick response.  They are VOB files that have been copied directly from the camera's disc to my PC.  When I burn discs directly from my PC without processing them thru Premiere, the video is fine.
            • 3. Re: Blurry Video after Burn
              The reason for the differences is that with the latter, you are just copying the existing MPEG-2 files to disc. With the former (editing), there is a second MPEG-2 compression going on.
              The only ways around that are:
              1.) do not use previously Transcoded MPEG-2 footage, or to use an NLE that does "smart Rendering," and do not really edit much - just cut out sections.
              This was what I suspected.
              • 4. Re: Blurry Video after Burn
                Kodebuster Level 3
                For best results with VOB's I would first convert to DV-AVI, then import the DV-AVI file into PE for editing.
                I use this approach for editing with my Mini-DVD Camera, and to rip DVD's from my DVD-Recorder for editing with PE.
                For me personally, I've found the results to be acceptable without blur on output from PE.
                Here's my post from another thread with details:
                If you want to rip from a DVD and then import into PE for editing, what I found works best is to convert the VOB files into DV-AVI.
                There can be issues with the sync of audio/video when a single DVD has multiple VOB's on it, but once you get past that hurdle, there are a number of free packages that will convert to DV-AVI.
                This link shows how to fix the VOB sync issue (if needed):
                http://muvipix.com/phpBB3/viewtopic.php?f=38&t=2469
                But first I would convert the VOB(s) via Prism and see how that goes.
                This link gives you the latest DV-AVI convert software options (I've used Prism and would not hesitate to recommend):
                http://forums.adobe.com/thread/415317?tstart=0
