0 Replies Latest reply on Jan 15, 2010 5:00 PM by Deeptika Gottipati
    [svn:fx-trunk] 13542: Adding the files that were removed in revision 13519.
    Deeptika Gottipati Adobe Employee
      Revision: 13542
      Revision: 13542
      Author:   deeptika@adobe.com
      Date:     2010-01-15 17:00:37 -0800 (Fri, 15 Jan 2010)
      Log Message:
      Adding the files that were removed in revision 13519. This is to make the merge from 4.0.0 branch easier. These changes are already made to 4.0.0 branch in revision 13522.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run:
      Is noteworthy for integration:
      Added Paths:
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SprakTextAreaAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SprakTextInputAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SprakSkinnableTextBaseAutomationImpl.as
