2 Replies Latest reply on Jan 16, 2010 7:05 AM by the_wine_snob
    No Audio on DVD
    francis_moses
      Hi ,
      I have just aquired Adobe Premiere Elements8, and since I have never used this programme nor any other editing programme before, I am battling to get to grips with the basics in the shortest possible time.  I am able to get to the point of readiness to burn a DVD from a file on my hard drive. This file was captured using Windows DVD maker and a JVC DV900 video camera. However after going through the whole process the resultant DVD has no sound.  I need help as I have exhausted my meager knowledge and using too many DVDs.   Thank you heaps
        • 1. Re: No Audio on DVD
          nealeh Level 5
          I don't have an answer for your sound problem but you can save on DVD's by burning your project to a folder. This creates a folder on your PC containing your project exactly as if you had burnt it to DVD. You can then play this DVD with a software player (e.g. PowerDVD, Windows Media Centre, VLC Media Player etc ...).
          When you are ready to test your project on a DVD Player use a rewritable DVD first (most modern players can cope with DVD+RW & DVD-RW).
          Cheers,
          Neale
          • 2. Re: No Audio on DVD
            the_wine_snob Level 9
            Welcome to the forum.
            I could not find specs. on this camera, so you will need to help us a bit with the specifications of the resultant footage.
            Probably the easiest, especially since the footage was captured from another program, would be to download the free utility, G-Spot, and run one of the files through that. It will tell you the full specifications. To save you a lot of typing, just do a screen-cap of the G-Spot screen, with the file loaded in.
            Most JVC cameras capture in a proprietary format, MOD for SD footage, and TOD for HD footage. These can cause problems with PrE, though usually with Import. Still knowing the full specs. of the captured files will go a long way to solving this mystery.
            Now, a few questions:
            1.) can you hear the audio, when you play the Timeline in PrE.?
            2.) have you added any audio, say MP3 soundtracks?
            3.) what brand of blank media have you been using?
            A note: Neale's suggestion of Burn to Folder, as a test, is a good one, as that will take the blank media out of the equation.
            4.) with your test DVD, have you tried playing it on both a computer and on a set-top DVD player? What is the result of both tests?
            Good luck, and we look forward to hearing the answers to those questions
