1. Re: snapshots vs. layer comps
Zeno Bokor Jan 16, 2010 9:20 AM (in response to Christian Davideck)i don't see the problem, layer comps can save the layer position, just make sure that you select the Position checkbox when you make the layer comp
2. Re: snapshots vs. layer comps
Christian Davideck Jan 16, 2010 10:43 AM (in response to Zeno Bokor)to see the problem, please read OP again, or tell me which part of the OP was unclear for you. thank you.
3. Re: snapshots vs. layer comps
Zeno Bokor Jan 16, 2010 10:51 AM (in response to Christian Davideck)I read it 5 times now and still don't understand the part with the question
Select the first snapshot, go to the Layer Comps panel, click the new layer comp button and select all 3 checkboxes.
Select the second snapshot, go to the Layer Comps panel, click the new layer comp button and select all 3 checkboxes.
I don't see why this wouldn't work.
4. Re: snapshots vs. layer comps
Christian Davideck Jan 16, 2010 11:01 AM (in response to Zeno Bokor)Okay, then sorry Zeno. I thought you just brushed over it.
Select the second snapshot, go to the Layer Comps panel, ...
As soon as you go to the second snapshot, the Layer Comps panel is empty (i.e. you just lost the Layer Comp you created from snapshot 1). That's the problem.
I didn't mention this Photoshop behaviour explicitely in the OP, thinking it would be common knowledge.
5. Re: snapshots vs. layer comps
Zeno Bokor Jan 16, 2010 11:22 AM (in response to Christian Davideck)ok, understood your problem (i don't bother with snapshots all that much). First select the bottom most snapshot and then select the first one and make a new layer comp. Go to the Last Document State layer comp and make your second layer comp based on that and you're done.
(For whatever reason, if you first select the top most snapshot and then the one below it, it won't work so make sure that you first select the bottom most one)
6. Re: snapshots vs. layer comps
Christian Davideck Jan 16, 2010 11:35 AM (in response to Zeno Bokor)Cool. Thank you, Zeno! You solved it.
Well, in that case, Photoshop's behaviour is inconsistant.
"For whatever reason, ..."
7. Re: snapshots vs. layer comps
Christian Davideck Jan 22, 2010 12:18 AM (in response to Zeno Bokor)okay, as nobody seems to be able to explain this Photoshop behaviour, I will mark your answer as the correct one, Zeno, being the one which solved the problem. I think in absence of any explanation, this has to be considered a bug and I will file a report when I have the time. Thanks again for helping, Zeno.
