1. Re: Burn Blu - ray in Encore CS4
Jon Geddes Jan 19, 2010 7:24 AM (in response to macergodt)We burn many Blu-ray projects using our motion menu template products.
What seems to be your problem?
2. Re: Burn Blu - ray in Encore CS4
macergodt Jan 20, 2010 11:16 AM (in response to Jon Geddes)Hey
My problems is :
We use a template that comes with Encore.
We link a button to a submenu or a chapter on the movie.
And burn it on blu- ray disc.
When vi play the blu - ray disc in a blu- ray player there comes about 2 sec. of black screen
when we press the button and into the submenu comes or the movie starts.
Do you also see that in your projekt ?
or is it an error ?
It only comes when we make a blu - ray projekt
and not in a normal DVD projekt.
3. Re: Burn Blu - ray in Encore CS4
Jon Geddes Jan 20, 2010 12:00 PM (in response to macergodt)It is normal for a player to briefly pause as it seeks the disc for the menu, transition, or video you are having it load. This is a limitation of the format.
Normally, a player will freeze the last frame of the previous menu until it loads the next menu or video. This freeze usually lasts 0.5 seconds to 1 second. If your disc was burned too fast, uses too high of a bitrate, had dust or scratches on the surface while burning or playing, this amount of time to seek the disc will increase (and possibly go to a black screen if it can't load it within a second or two).
The black screen you are experiencing is a player issue, not a menu issue. You might be able to reduce the freeze if you correct any issues you might have had with your disc. If your disc is flawless, then there is nothing you can do. If you try it on a different player, you will likely see a different result.
Menu content is stored on the disc in a different physical location than timeline content, which will make it take slightly longer to go from a menu to a timeline or vise versa.
4. Re: Burn Blu - ray in Encore CS4
macergodt Jan 21, 2010 1:16 PM (in response to Jon Geddes)Thanks for your answer.
You write that it is normal.
I have bean told that it isn´t normal , from the place there I have bought the programe.
From where do you no that is it normal ?
I have a Encore CS 4 projekt maded om my Mac , you can download , and try to burn on a blu- ray BD-RE disc,
there you can see that I mean about the black screen
between the button on a menu and to the submenu.
Here is the link :
http://www.hd-video.dk/adobe/encore.html
Regards
Mikael from Denmark
5. Re: Burn Blu - ray in Encore CS4
Jon Geddes Jan 21, 2010 1:48 PM (in response to macergodt)I am downloading now. I will test when it completes and get back to you on what I find.
Edit: Please create a Blu-ray Image file (*.iso) and upload that only. Thank you.
