3 Replies Latest reply on Jan 18, 2010 8:10 PM by Benoitcn
    Error while select or over the menubar first time ~
    Benoitcn Level 1
      I have a lot of codes in the main.mxml, so I cut most of them.
      And I don't use the any kinds of the css styles.The code is actually created by FlashCatalyst.
      The menubar dosen't have the skinclass property so I is added manually.
      I have attached the main.mxml.  Thanks a lot !
      <?xml version='1.0' encoding='UTF-8'?>
      <s:Application xmlns:ATE="http://ns.adobe.com/ate/2009"
            xmlns:ai="http://ns.adobe.com/ai/2009"
            xmlns:fc="http://ns.adobe.com/flashcatalyst/2009"
            xmlns:d="http://ns.adobe.com/fxg/2008/dt"
            xmlns:fx="http://ns.adobe.com/mxml/2009"
            xmlns:lib="assets.graphics.transation.*"
            xmlns:flm="http://ns.adobe.com/flame/2008"
            backgroundColor="#ffffff"
            height="100%" preloaderBaseColor="#ffffff"
            width="100%"  creationComplete="application1_creationCompleteHandler(event)"
            xmlns:mx="library://ns.adobe.com/flex/halo">
      <fx:Script>
        <![CDATA[
         import mx.collections.XMLListCollection;
         import mx.events.FlexEvent;
         [Bindable]
         private var MenuBarDataList:XMLListCollection;
         private var MenuBarData:XMLList=
           <menuitem label="Menu1">
            <menuitem label="MenuItem 1-A" data="1A"/>
            <menuitem label="MenuItem 1-B" data="1B"/>
           </menuitem>
           <menuitem label="Menu2">
            <menuitem label="MenuItem 2-A" type="check"  data="2A"/>
            <menuitem type="separator" />
            <menuitem label="MenuItem 2-B" >
             <menuitem label="SubMenuItem 2-B-A" type="radio"
              groupName="2one" data="2-B-A"/>
             <menuitem label="SubMenuItem 2-B-B" type="radio"
              groupName="2one" data="2-B-B"/>
            </menuitem>
           </menuitem>
           <menuitem label="Menu3">
            <menuitem label="MenuItem 3-A" type="check"  data="3A"/>
            <menuitem label="MenuItem 3-B" >
             <menuitem label="SubMenuItem 3-B-A" type="radio"
              groupName="3one" data="3-B-A"/>
             <menuitem label="SubMenuItem 3-B-B" type="radio"
              groupName="3one" data="3-B-B"/>
            </menuitem>
           </menuitem>
      protected function application1_creationCompleteHandler(event:FlexEvent):void
          MenuBarDataList = new XMLListCollection(MenuBarData);
      </fx:Script>
         <s:Group>
           <mx:MenuBar id="topNavMenu" includeIn="main" x="518" y="25.95" height="22"
                dataProvider="{MenuBarDataList}" labelField="@label" />
      </s:Group>
      </s:Application>
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at mx.controls::Menu/updateDisplayList()[E:\dev\gumbo_beta2\frameworks\projects\framework\sr c\mx\controls\Menu.as:1372]
      at mx.controls.listClasses::ListBase/validateDisplayList()[E:\dev\gumbo_beta2\frameworks\pro jects\framework\src\mx\controls\listClasses\ListBase.as:3969]
      at mx.managers::LayoutManager/validateDisplayList()[E:\dev\gumbo_beta2\frameworks\projects\f ramework\src\mx\managers\LayoutManager.as:663]
      at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\gumbo_beta2\frameworks\projects \framework\src\mx\managers\LayoutManager.as:736]
      at mx.managers::LayoutManager/validateNow()[E:\dev\gumbo_beta2\frameworks\projects\framework \src\mx\managers\LayoutManager.as:794]
      at mx.controls::Menu/show()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\controls \Menu.as:1697]
      at mx.controls::MenuBar/showMenu()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\c ontrols\MenuBar.as:1877]
      at mx.controls::MenuBar/mouseDownHandler()[E:\dev\gumbo_beta2\frameworks\projects\framework\ src\mx\controls\MenuBar.as:2070]
        • 1. Re: Error while select or over the menubar first time ~
          Benoitcn Level 1
          Does anybody know why the error come from the border which in the updateDisplayList
          override protected function updateDisplayList(unscaledWidth:Number,
                                                            unscaledHeight:Number):void
                  super.updateDisplayList(unscaledWidth, unscaledHeight);
                  border.move(0, 0); // error born here
                  border.visible = (dataProvider != null && dataProvider.length > 0);
          at mx.controls.listClasses::ListBase/validateDisplayList()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\controls\listClasses\ListBase.as:3 969]
          at mx.managers::LayoutManager/validateDisplayList()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\managers\LayoutManager.as:663]
          at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\managers\LayoutManager.as:736]
          at mx.managers::LayoutManager/validateNow()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\managers\LayoutManager.as:794]
          at mx.controls::Menu/show()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\controls\Menu.as:1697]
          at mx.controls::MenuBar/showMenu()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\controls\MenuBar.as:1877]
          at mx.controls::MenuBar/mouseDownHandler()[E:\dev\gumbo_beta2\frameworks\projects\framework\src\mx\controls\MenuBar.as:2070]
          • 2. Re: Error while select or over the menubar first time ~
            Peter deHaan Level 4
            @Benoitcn,
            I'm not seeing any errors when using the following code:
                           xmlns:mx="library://ns.adobe.com/flex/mx"
                           creationComplete="application1_creationCompleteHandler(event);">
                <fx:Script>
                    <![CDATA[
                        [Bindable]
                             </menuitem>
                              </menuitem>
                             </menuitem>
                              </menuitem>
                             </menuitem>
                </fx:Script>
                <s:Group>
                    <mx:MenuBar id="topNavMenu" x="518" y="25.95" height="22"
                </s:Group>
            </s:Application>
            Are you still seeing the error if you change to the latest nightly Flex 4.0 build? http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
            Peter
            • 3. Re: Error while select or over the menubar first time ~
              Benoitcn Level 1
              Yes, but I think I found the problem.
              The workflow is Illustrator -> Flash Catalyst -> Flash Builder with Gumbo
              If I put up the project on the Tomcat using BlazeDS, the error come out !
              在2010-01-19?04:48:24,"Peter?deHaan?(Adobe)"?<forums@adobe.com>?写道:
              >@Benoitcn,
              >I'm?not?seeing?any?errors?when?using?the?following?code:
              ><?xml?version='1.0'?encoding='UTF-8'?>
              ><s:Application?xmlns:fx="http://ns.adobe.com/mxml/2009"
              >???????????????xmlns:s="library://ns.adobe.com/flex/spark"
              >???????????????xmlns:mx="library://ns.adobe.com/flex/mx"
              >???????????????creationComplete="application1_creationCompleteHandler(event);">
              >????<fx:Script>
              >????????<![CDATA[
              >????????????import?mx.collections.XMLListCollection;
              >????????????import?mx.events.FlexEvent;
              >????????????[Bindable]
              >????????????private?var?MenuBarDataList:XMLListCollection;
              >????????????private?var?MenuBarData:XMLList=
              >?????????????????<menuitem?label="Menu1">
              >??????????????????<menuitem?label="MenuItem?1-A"?data="1A"/>
              >??????????????????<menuitem?label="MenuItem?1-B"?data="1B"/>
              >?????????????????</menuitem>
              >?????????????????<menuitem?label="Menu2">
              >??????????????????<menuitem?label="MenuItem?2-A"?type="check"??data="2A"/>
              >??????????????????<menuitem?type="separator"?/>
              >??????????????????<menuitem?label="MenuItem?2-B"?>
              >???????????????????<menuitem?label="SubMenuItem?2-B-A"?type="radio"
              >????????????????????groupName="2one"?data="2-B-A"/>
              >???????????????????<menuitem?label="SubMenuItem?2-B-B"?type="radio"
              >????????????????????groupName="2one"?data="2-B-B"/>
              >??????????????????</menuitem>
              >?????????????????<menuitem?label="Menu3">
              >??????????????????<menuitem?label="MenuItem?3-A"?type="check"??data="3A"/>
              >??????????????????<menuitem?label="MenuItem?3-B"?>
              >???????????????????<menuitem?label="SubMenuItem?3-B-A"?type="radio"
              >????????????????????groupName="3one"?data="3-B-A"/>
              >???????????????????<menuitem?label="SubMenuItem?3-B-B"?type="radio"
              >????????????????????groupName="3one"?data="3-B-B"/>
              >????????????protected?function?application1_creationCompleteHandler(event:FlexEvent):void
              >????????????????MenuBarDataList?=?new?XMLListCollection(MenuBarData);
              >????</fx:Script>
              >????<s:Group>
              >????????<mx:MenuBar?id="topNavMenu"?x="518"?y="25.95"?height="22"
              >????????????????????dataProvider=""?labelField="@label"?/>
              >????</s:Group>
              ></s:Application>
              >Are?you?still?seeing?the?error?if?you?change?to?the?latest?nightly?Flex?4.0?build??http://opensource.adobe.com/wiki/display/flexsdk/DownloadFlex4
              >Peter
