0 Replies Latest reply on Jan 18, 2010 1:01 AM by anaping wan
    about the socket security problem,Plese help.
    anaping wan Level 1
      I use the port 843 server to send xml to swf.But not work. Please help. My Code is:
      Server:
      //HelloTest.java
      import java.io.IOException;
      import java.net.ServerSocket;
      import java.net.Socket;
      //让其继承线程类是为了更好控制 其余的线程
      public class HelloTest extends Thread {
      * @param args
      public static void main(String[] args) {
      // TODO Auto-generated method stub
      //发送策略的服务器
      new HelloTest().start();
      //这个是用的fuq
      new Thread(new QtServer()).start();
      @Override
      public void run()
      System.out.println("策略服务器启动");
        boolean lising=true;
      ServerSocket ss;
      try {
      ss = new ServerSocket(843);
      while(lising)
      try {
      //得到socket服务器
        Socket sc=ss.accept();
      SendPolicyFile sp=new SendPolicyFile(sc);
      System.out.println("为什么呢");
      new Thread(sp).start();
      } catch (IOException e) {
      // TODO Auto-generated catch block
      e.printStackTrace();
      try {
      Thread.sleep(1000);
      } catch (InterruptedException e) {
      ss.close();
      } catch (IOException e1) {
      e1.printStackTrace();
      //SendPolicyFile.java
      import java.io.InputStream;
      import java.io.OutputStream;
      import java.io.PrintWriter;
      public class SendPolicyFile implements Runnable {
      private Socket soc;
      private OutputStream _socketOut;
      private InputStream _socketIn;
      public SendPolicyFile(Socket s) throws IOException
      this.soc=s;
      _socketOut=s.getOutputStream();
      _socketIn=s.getInputStream();
      //设置超时的限制
      //soc.setSoTimeout(1000);
      public void run() {
          try {
      readRandSp();
      @SuppressWarnings("unused")
      private void readRandSp() throws IOException
        if(read().equals("<policy-file-request/>"))
        System.out.println("write Policy to flash");
        writePolicy();
              //close stream and socket
        close();
      //写策略文件的方法
      private void writePolicy() throws IOException
         String string1="<?xml version=\"utf-8\" ?><cross-domain-policy><site-control permitted-cross-domain-policies=\"master-only\"/><allow-access-from domain=\"*\" to-ports=\"8001\"/></cross-domain-policy>"+"\u0000";
      PrintWriter pw=new PrintWriter(_socketOut);
      pw.println(string1+"\u0000");
      pw.flush();
      pw.close();
      System.out.println(string1+"\u0000");
      //关闭流
      //关闭socket
      public void close()
        if(_socketOut!=null)
      try {
      _socketOut.close();
      if(_socketIn!=null)
        _socketIn.close();
        if(soc!=null)
        soc.close();
      _socketIn=null;
      _socketOut=null;
      soc=null;
      //发送两个Socket
      private String read() throws IOException
      System.out.println("这里也执行吗");
      StringBuffer buffer=new StringBuffer();
      int codePoint;
      boolean zeroByteRead=false;
      do{
      //这个地方阻塞了
      codePoint=this._socketIn.read();
      //如果接受到的codePoint为null那证明客户端与我们失去连接了
      if(codePoint==0)
        zeroByteRead=true;
      else
      buffer.appendCodePoint(codePoint);
      while(!zeroByteRead && buffer.length()<30);
      return buffer.toString();
      // WqService.java
      import java.awt.List;
      public class WqService {
           private List list;
           public WqService(List list)
          this.list=list;
           //发送信息给一个用户
           public void sentToOne(User user,String  str)
          PrintWriter pw=new PrintWriter(user.outputStream);
          pw.println(str);
          pw.close();
           //发送信息给两个用户
           public void sentToBoth()
