5 Replies Latest reply: Jan 19, 2010 5:27 PM by dec9 RSS
    "Failed to Install"
    Chrsitian Community Member
      I am running Adobe Creative Suite, CS4 on 64 bit Vista. When I downloaded Adobe updates they all failed to install.  I got error messages for them which basically all read like the attached jpg.
      I beieve it must have something to do with the firewall or pop-up blocker, but am not sure how to proceed.
      My computer asked 'to proceed' when I downloaded the updates, and I 'gave permission.'
      Any help with this would be greatly appreciated.
        • 1. Re: "Failed to Install"
          dec9 Community Member
          If you have PS CS4 running exit from the program  before install.
          Go into windows task manager and verify there are no adobe products running in the background (except the updater of course).
          If all else fails you can do the manual download. Once downloaded, right click on the icon and run as Admin. Ensure there are no adobe software products running in the background
          • 2. Re: "Failed to Install"
            Many thanks - I will give that a try. Somehow I don't think I had any Adobe stuff open, but I am not sure.
            • 3. Re: "Failed to Install"
              If you think something is running in the background during update check:
              Right click on the Vista bottom tool bar to bring up task manager. Look to see nothing adobe is running in applications. Go to the processes tab and click on processes from all users and look for any adobe application running (Adobe reader). If found click on it and end process.
              Go to Start, start search and type in MSconfig. Click on startup tab and look for any adobe product that is checked and un-check it. Anything changed will need a reboot of the PC.
              Ok, as far as the popup issue go to internet options, privacy and uncheck popup blocker, hit apply and ok to close out. Then restart internet explorer
              If you are on a router and it has a built in firewall (most do) you want to turn off windows firewall. Go to Start, start search and type in windows firewall. Look at the top left and click on Turn windows Firewall on or off. A window will pop up. Select Off, hit apply then ok. Close out the other window.
              Now try the updater again.
              • 4. Re: "Failed to Install"
                wow, thanks SO much - I will do that!
                Why do 'they' make it so compicated???
                • 5. Re: "Failed to Install"
                  Who is they? lol........ often wondered that myself
