0 Replies Latest reply on Jan 18, 2010 6:19 AM by zzipper7
    MySQL results to array for string or varible for other table insert
    zzipper7 Level 1
      Hi all,
      I hope I’m in the right Forum, there are so many now.
      I’m using my DB as a cart with each row having an item. I want to pull all of the rows into one array or string to add to another table.
      I have a While loop that
      while ($row_cart = mysql_fetch_assoc($cart))
          foreach ($row_cart as $item)
                      $array[] = $data[];
      print_r($array)  OK  -one big array
      So all my data is in one array (multi-dimensional) I assume.
      The kicker is, when I serialize it, then unserialize it…the unserialzed array prints fine....but its blank if I try to implode it.
      $save_string = base64_encode(serialize($thisrow));
      $undo=unserialize(base64_decode($save_string));
      print_r($undo) OK  -one big array
      Many failed attempts to break this down so I can implode in to a string:
      $mydata = $undo;
      for ($i=0;  $i<$itemcount; $i++) {
      print_r($mydata) . ' | ';
      Prints:  Array| Array| Array| Array|
      I have many other attempts, I’m able to count the array elements, but when its time to implode to a string, it always prints empty. "|||||||"
      I think my problem is in the loop, I’m not setting up the right array. Thoughts anyone??
