3 Replies Latest reply on Jul 18, 2010 1:15 AM by HIIIIIII
    Debugging error
    bertbaeck
      When debugging I recieve following pop-up:
      When looking for this file "LIBRARY>>INTERNET PLUG_IN" I can find this file!  What's wrong?!
      Thanks a lot for helping!!
        • 1. Re: Debugging error
          Gregory Lafrance Level 6
          This happens a lot when using Flex Builder 3 and on the same machine Flash Builder 4 beta.
          It can also happen when you use Flex Builder 3 on the same machine as Flash Authoring.
          Just download the Flash Player 9 and 10 debug versions from this web site and reinstall the version the message box indicates should be installed.
          http://www.adobe.com/support/flashplayer/downloads.html
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: Debugging error
            bertbaeck Level 1
            Hi Greg,
            Thanks for your answer...
            Your first solution is not likely is assume. There is no FlasH builder 4 beta on my MAC.
            Your second solution might be the one for me . I have to check this hypotesis.
            I am just going to repeat your answer just to be sure i do it the right way.
            1. Install Flash Player 9 and 10 debug versions
            2. Uninstall Adobe Flex Builder 3
            3. Reinstall Adobe Flex builder
            Thanks in advance,
            Bert
            • 3. Re: Debugging error
              HIIIIIII
              Hi Greg Lafrance
              I tried your solution but it was not work.
              im using flex builder 3 pro, and im working on actionscript project, wwhen im try to debugg the project it showes the launching progress bar, last it sayes failed to connect; session timed out.
              when im not using the internet connection a dialog box come up sayes to download the new version of flash player.
              but when i connected the progress bar shows.
              so i tried to uninstall the flex builder and then install the flashplayer_10_ax_debug, then reinstall the flex builder but not working.
              by the way i did install the FlashBuilder before flex but i faced same issue. so plz help me on this
              and thanks alot
