12 Replies Latest reply on Jun 12, 2008 5:13 AM by olimpiu.pop
    WebService connection problem
    olimpiu.pop
      Hello,
      I am a fairly new to Flex, I`m trying to build an application that has the client side built using Flex
      and the back built using Spring WS - this exposes web services that should be consumed bu the
      Flex application.
      My problem is that: when I try to test my Web Service from Flex I get the following exception:
      [RPC Fault faultString="Security error accessing url" faultCode="Channel.Security.Error" faultDetail="Unable to load WSDL. If currently online, please verify the URI and/or format of the WSDL ( http://localhost:8080/ams/services/login/login.wsdl)"
      at mx.rpc.wsdl::WSDLLoader/faultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\ws dl\WSDLLoader.as:98]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()[E:\dev\3.0.x\frameworks\pro jects\rpc\src\mx\rpc\AbstractInvoker.as:168
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()[E:\dev\3.0.x\frameworks\project s\rpc\src\mx\rpc\AbstractInvoker.as:220
      at mx.rpc::Responder/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\Responder.as:49 ]
      at mx.rpc::AsyncRequest/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\AsyncRequest .as:103]
      at DirectHTTPMessageResponder/securityErrorHandler()[E:\dev\3.0.x\frameworks\projects\rpc\sr c\mx\messaging\channels\DirectHTTPChannel.as:368]
      at flash.net::URLLoader/redirectEvent()
      The WSDL is accesible both from a browser (Firefox) and from SOAPUI as well.
      The Flex code is:
      Thanks for your help
