1 Reply Latest reply on Jan 18, 2010 2:39 PM by Bad Prop Gun Productions
    Flash FLV Player (XML Driven) works locally, not online
    Bad Prop Gun Productions Level 1
      I have been beating my head into the walls on this one.
      I have an actions layer and a layer with a video object, called "theVideo". Below is the actionscript:
      stop();
      // global objects....
      buffer._visible = false;
      // playlist object for the playlist from raw xml data
      var playlistData:Object = new Object();
      playlistData.list = new Array();
      // Create a videos object to hold a video
      var videos:Object = new Object();
      // create variable for keeping count of videos played
      var hasPlayed:Object = new Object();
      // create variable for tracking buffer
      var hasBuffered:Object = new Object();
      // create variable for total movies to be played
      var quantity:Object = new Object();
      function loadXML(loaded) {
        if (loaded) {
          xmlNode = this.firstChild;
          total = xmlNode.childNodes.length;
          for (i=0; i<total; i++) {
            playlistData.list[i] = xmlNode.childNodes[i].childNodes[0].firstChild.nodeValue;
            descriptions.list[i] = xmlNode.childNodes[i].childNodes[1].firstChild.nodeValue;
          trace ("Loaded "+total+" entries from XML source.");
        } else {
          content = "file not loaded!";
      trace("Trying to start vids...");
      hasplayed = 0;
      hasBuffered = 0;
      startVids();
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
      var myChannel:String = _level0.channel;
      var myEpisode:String = _level0.episode;
      //var myXmlFile:String = "xml.php?channel=0&episode=0";
      var myXmlFile:String = "xml.xml";
      xmlData.load(myXmlFile);
      function startVids() {
        trace("Made it to start vids. Making a new connection...");
      // Create a NetConnection object:
        var nc:NetConnection = new NetConnection();
        trace("Net connection to null...");
      // Create a local streaming connection:
        nc.connect(null);
        trace("New netstream connection...");
      // Create a NetStream object and define an onStatus() function:
        var ns:NetStream = new NetStream(nc);
        trace("Set the time to buffer");
      // Set the buffer time:
        ns.setBufferTime(5);
        trace("Attching netstream to instance of video");
      // Attach the NetStream video feed to the Video object:
        theVideo.attachVideo(ns);
        theVideo.addEventListener("complete",nsListener);
        ns.onStatus = function(info) {
        if(info.code == "NetStream.Buffer.Full") {
      // Do Nothing (used for buffer message later)
        if(info.code == "NetStream.Buffer.Empty") {
        if(info.code == "NetStream.Play.Stop") {
          loadNext();
      trace("Play the first video in the lineup, which is "+playlistData.list[0]);
      // Being playing the FLV file:
      ns.play(playlistData.list[hasplayed]);
      trace("Set hasplayed to 1");
      // hasplayed++;
      trace("Get quantity, which is "+playlistData.list.length);
      quantity = playlistData.list.length;
      nsListener.complete = function( evt:Object ):Void {
          loadNext();
      function loadNext() {
        if(hasplayed < quantity) {
          clearInterval(myInt);
           hasplayed += 1;
           startVids();
      } else {
           ns.close();
      ************************END ACTIONSCRIPT*************************
      This script works locally. I have checked and double-checked the file locations when uploaded. It will parse the XML file when uploaded, but will not play the videos.
      Many, MANY thanks in advance.
