0 Replies Latest reply on Jan 18, 2010 3:24 PM by jmurphy67
    [svn:fx-4.0.0] 13595: split airframework from airspark docs
    jmurphy67 Level 1
      Revision: 13595
      Revision: 13595
      Author:   jimurphy@adobe.com
      Date:     2010-01-18 15:24:33 -0800 (Mon, 18 Jan 2010)
      Log Message:
      -delete airframework/bundles/[locale]/docs/spark xml's
      -add airspark/bundles/[locale]/docs/spark xml's
      -added airspark/bundles/en_US/ english properties
      -modified airspark/build to:
        -use en_US properties for each of the locales until localized
        -use the localized spark doc files for each locale in the fat-swc target
      QE notes:
      Doc notes: code hinting should be localized for airspark
      Bugs: http://bugs.adobe.com/jira/browse/SDK-25065
      Reviewer: gaurav
      Tests run: full build,checkintests,doc,other.locales
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/build.xml
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/spark.accessibili ty.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/spark.components. windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/spark.components. xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/spark.skins.spark .windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/spark.skins.spark .xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/SharedResources.proper ties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/collections.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/containers.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/controls.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/core.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/effects.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/formatters.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/skins.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/en_US/styles.properties
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/spark.accessibili ty.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/spark.components. windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/spark.components. xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/spark.skins.spark .windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/spark.skins.spark .xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/spark.accessibili ty.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/spark.components. windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/spark.components. xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/spark.skins.spark .windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/spark.skins.spark .xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/spark.accessibili ty.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/spark.components. windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/spark.components. xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/spark.skins.spark .windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/spark.skins.spark .xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/spark.accessibili ty.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/spark.components. windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/spark.components. xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/spark.skins.spark .windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/spark.skins.spark .xml
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/spark.accessi bility.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/spark.compone nts.windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/spark.compone nts.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/spark.skins.s park.windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/spark.skins.s park.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/spark.accessi bility.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/spark.compone nts.windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/spark.compone nts.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/spark.skins.s park.windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/spark.skins.s park.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/spark.accessi bility.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/spark.compone nts.windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/spark.compone nts.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/spark.skins.s park.windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/spark.skins.s park.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/spark.accessi bility.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/spark.compone nts.windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/spark.compone nts.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/spark.skins.s park.windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/spark.skins.s park.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/spark.accessi bility.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/spark.compone nts.windowClasses.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/spark.compone nts.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/spark.skins.s park.windowChrome.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/spark.skins.s park.xml
