2 Replies Latest reply on Jan 19, 2010 10:26 AM by gkaiseril
    Using an option box with a calculation
    campy3 Level 1
      I have a calculation question for the group.  I am trying to calculate creatinine clearance.  Seems easy, but im getting stuck at the end.
      creatinine clearance is : ((140-age)*weight (kg))  / (72*Scr)
      Women are multiplied by 0.85 to get the final creatinine clearance result
      I have a box for age, weight, and scr and the user enters the number.
      Where I am getting stuck at is the end...I have an option checkbox for women so that the result is multiplied by 0.85.  I thought something like this might work...but to no avail.
      var crcl2
      crcl2 = (140 - this.getField('age').value) * (this.getField('weight').value) / (72 * this.getField('cr').value);
      var crcl3
      function validate(carbbox)
      if (carbbox.checked == 1)
      crcl3 == crcl2 * 0.85;
      else
      crcl3 == crcl2;
      Im kinda new at this obviously....any help would be really appreciated.
      thanks, chris
        • 1. Re: Using an option box with a calculation
          Problem 1: You're not calling the function anywhere in this code, just
          defining it.
          Either drop the function definition, or call it from somewhere.
          Problem 2: You're using the comparator (==) instead of the value assign (=)
          operator in two places.
          Problem 3: You're using "else" without placing the code before it in a block
          (by placing curly brackets around it).
          There are probably more, but that's the ones I see now...
          • 2. Re: Using an option box with a calculation
            Unless you are repeating the calculation in the function at multiple places with different values or want a library type funciton that could be adeed to other forms, use of the function may not be needed.
            event.value = ''; // assume calculation not performed
            // perform calculation if divisor is not zero
            if (this.getField('cr').value != 0) {
               // adjustment for gender
               var adjGender = 1;
               if (if(this.getField("carbbox").value == 1) {
                  adjGender = 0.85; // adjustment for female gender
                  } // end adjustment for gender
               // compute creatinine clearance
               event.value = (140 - this.getField('age').value) * ( this.getField('weight').value) / (72 *
               this.getField('cr').value)  ) * adjGender;
            } // end of computation
