0 Replies Latest reply on Jan 18, 2010 4:54 PM by Paul Reilly
    [svn:fx-4.0.0] 13601: * Fixed a regression caused by revision 13531.
    Paul Reilly Level 1
      Revision: 13601
      Revision: 13601
      Author:   preilly@adobe.com
      Date:     2010-01-18 16:54:16 -0800 (Mon, 18 Jan 2010)
      Log Message:
      • Fixed a regression caused by revision 13531.
      QE notes:
      Doc notes:
      Bugs: SDK-25115
      Reviewer: Gaurav, Pete
      Tests run: checkintests
      Is noteworthy for integration: no
      Code-level description of changes:
        StyleDef.java
          Modified extractImports() by adding a "null" value check for
          ClassReferences.
          Modified processReference() to use Reference's updated
          constructor.
        Reference.java
          Modified constructor by adding a isClassReference parameter.
          Removed setClassReference(), because it's no longer used.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25115
      Modified Paths:
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/css/Reference.java
          flex/sdk/branches/4.0.0/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
