0 Replies Latest reply on Jan 18, 2010 7:57 PM by jmurphy67
    [svn:fx-4.0.0] 13614: additional update for airspark, added packages. dita to svn and instead of unzipping properties from airspark_rb the locales will simply use the files from the en_US directory until the localized files are submitted .
    jmurphy67 Level 1
      Revision: 13614
      Revision: 13614
      Author:   jimurphy@adobe.com
      Date:     2010-01-18 19:56:49 -0800 (Mon, 18 Jan 2010)
      Log Message:
      additional update for airspark, added packages.dita to svn and instead of unzipping properties from airspark_rb the locales will simply use the files from the en_US directory until the localized files are submitted.
      QE notes:
      Doc notes: code hinting should be localized for airspark
      Bugs: http://bugs.adobe.com/jira/browse/SDK-25065
      Reviewer: gaurav
      Tests run: full build,checkintests,doc,other.locales
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/build.xml
      Added Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/packages.dita
