0 Replies Latest reply on Jan 18, 2010 9:04 PM by jmurphy67
    [svn:fx-4.0.0] 13615: fix airframework/build. xml so the en_US _rb does not become corrupt when the other. locales target is run.
    jmurphy67 Level 1
      Revision: 13615
      Revision: 13615
      Author:   jimurphy@adobe.com
      Date:     2010-01-18 20:59:14 -0800 (Mon, 18 Jan 2010)
      Log Message:
      fix airframework/build.xml so the en_US _rb does not become corrupt when the other.locales target is run.
      -removed the redundant en_US call in the other.locales target
      -added a clean for locales that will only remove the locale being built before rebuild - not all of the locales
      -add updated dita that does not contain spark references
      QE notes:
      Doc notes:
      Bugs: no but Pete and I discussed briefly
      Reviewer:
      Tests run: doc and other.locales
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/packages.dita
