0 Replies Latest reply on Jan 18, 2010 9:56 PM by jmurphy67
    [svn:fx-trunk] 13618: Localization property file update 4.0.0.13607
    jmurphy67 Level 1
      Revision: 13618
      Revision: 13618
      Author:   jimurphy@adobe.com
      Date:     2010-01-18 21:56:28 -0800 (Mon, 18 Jan 2010)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/SharedResources.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/formatters.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_TW.properties
