6 Replies Latest reply on Jan 19, 2010 10:42 AM by Marc de kwant
    Events from custom components
    mw00
      Hi, I have set up a ViewStack component as seen below, what I would like to do is change the item on display when a button is pressed from within one of the custom canvases e.g. when PayAndLoadButton is pressed which is a child of MainProductCanvas i'd like to switch the ViewStack index to 1, the LoadScreen canvas.
          <mx:ViewStack id="productVs" x="0" y="0" selectedIndex="0">
              <customcanvases:MainProductCanvas/>
              <customcanvases:LoadScreen/>
          </mx:ViewStack>
      If I set up an actionscript function in the same file as the ViewStack above e.g...
          <mx:Script>
              <![CDATA[
                  public function changeStackIndex():void
                      productVs.selectedIndex = 1;
          </mx:Script>
      How do I refer to this function from within the child component?
      The child looks like this at the moment...
      <buttons:PayAndLoadButton x="650" y="632" id="payAndLoadButton" click="changeStackIndex()" />
      But I'm getting the error "Call to a possibly undefined method changeStackIndex", how do I refer to the parent script function?
      Another option is to place the function in a separate .as file which I could refer to using <mx:Script source="... tag but then how do I refer to the parent ViewStack id from within the .as file?
      TIA
      Mike.
        • 1. Re: Events from custom components
          Vanden_B
          What you can do is make a bindable variable in a Model for the selectedIndex and two constantes to use.
          public var productVsView:int = 0;
          public static const LALALA_0:int = 0;
          public static const LALALA_1:int = 1;
          Use in the viewstack: selectedIndex="{model.productVsView}">
          and do in the function this:
                          model.productVsView = ModelLocator.LALALA_1;
          Now, when the function is called, the variable is updated and through binding the viewstack index-property is changed.
          • 2. Re: Events from custom components
            Marc de kwant Level 1
            The steps you could take to make this work are the following:
            1. define an event (with metadata) in your child component
                <mx:Metadata>
                      [Event(name="changestack", type="flash.events.Event")]
                </mx:Metadata>
            + corrsponding event dispatching when needed.
            2. In your main mxml file (where the viewstack is and the child component) you refer to this event and handle it in a method, thus chaniging the index
               <mx:Script>
                    <![CDATA[
                            private function onStackChange():void {
               </mx:Script>
                    <customcanvases:LoadScreen changestack="onStackChange()"/>
                </mx:ViewStack>
            Kind regards,
            Marc
            ps. This code is not functional, but gives an idear as to solving your problem.
            • 3. Re: Events from custom components
              mw00 Level 1
              Thank you both for your help.
              As a general rule when writing flex apps is it best to keep all actionscript in separate files from the MXML or is it unavoidable or desirable to keep the 2 together in some cirumstances?
              • 4. Re: Events from custom components
                Vanden_B Level 1
                I don't know exactly about a best practice, but I use AS within my MXML class if this is specific to that class.
                I mostly use a MVC (Cairngorm) and therefore I define generic AS classes which can be triggered by events.
                ps: if the question is answered, mark it as such
                • 5. Re: Events from custom components
                  That is indeed à common practice. Personally I architect my flex
                  application True to design of flex and event bubbling in specific. I
                  do not like to Use à mvc framework, where there is in 99% of the cases
                  no need for.
                  But that is just my opinion
                  Marc
                  • 6. Re: Events from custom components
                    I see no difference in mxml and as code. Both are actioscript.
                    Therefore I mix them as I see fit. What I try to keep separate are my
                    programming concerns. View, controller and model. Or whtever yasye you
                    have.
                    Marc
