6 Replies Latest reply on Jan 20, 2010 11:51 AM by RyanOConnell
    sizing the MediaPlayerSprite
    nathan@blip.tv
      I have a mediaplayer sprite that i am adding to the stage via my main class (which extends sprite)
      I can not for the life of me get the display to scale down to a size...
      am i missing something?
      code below:
      package {
           //imports removed for brevity
           public class Stratos extends Sprite {
                //vars
                private var _videoDisplay:MediaPlayerSprite;
                private var _player:BlipPlayer;
                private var _progressBar:SimpleProgressBar;
                private var _videoSeekBar:SimpleProgressBar;
                public function Stratos():void {
                     stage.scaleMode = StageScaleMode.NO_SCALE;
                     stage.align = StageAlign.TOP_LEFT;
                     _player = new BlipPlayer('http://blip.tv/rss/whatever');
                     _player.addEventListener(BlipEvent.PLAYLIST_LOADED, onPlayerDataLoaded);
                     _videoDisplay = new MediaPlayerSprite(_player);
                     _videoDisplay.scaleMode = ScaleMode.LETTERBOX;
                     _videoDisplay.width = 200;  //why do you hate me?
                     _addChild(_videoDisplay);
      I have also worked a bit with the MediaPlayerCapabilityChangeEvent and the DIMENSION_CHANGE events to attempt some resizing on those events, to no avail...
      I am sure that i am overlooking something, most likely something simple - can anyone point me in the correct direction?
      Thank You in advance,
      -Nathan
      note: this was for some reason posted in the general discussions. I have moved the thread to the developer section and deleted the previous post.
        • 1. Re: sizing the MediaPlayerSprite
          jerryhamby Level 1
          My approach is more of a manual one. I'm using a basic Sprite and the standard MediaPlayer.
          I just use scaleX and scaleY. This may or may not work with the MediaPlayerSprite, I just haven't tested.
          I'm resizing images, so I get the original size of the image, I know the destination size, so I do some math to
          come up with a percentage. That percentage I use with scaleX and scaleY.
          pMediaSprite.scaleX = percentage;
          pMediaSprite.scaleY =  percentage;
          pMediaSprite.x =  0;
          pMediaSprite.y =  0;
          I do this on ViewEvent.DIMENSION_CHANGE event. Sprite 8 still has a bug here, but they say it is
          fixed in Sprint 9, we'll see.
          • 2. Re: sizing the MediaPlayerSprite
            RyanOConnell
            I noticed you are not setting the height, is that on purpose?  It won't scale down if you don't specify the height as well as the width.
            -Ryan O'Connell
            • 3. Re: sizing the MediaPlayerSprite
              nathan@blip.tv Level 1
              Thanks Guys,
              but even adding in the height does not work for me either.
              all i am trying to do is scale the movie down to fit into a ceartain size.
              Is this the way that others are doing it?
              I tried using the method jerry proposed (assuming that pMediaSprite is MediaPlayer.view) earlier and that is when i added in the mediaPlayerSprite - I thought that had some special sauce that i knew nothing about.
              Any other help is greatly appreciated,
              Thank You,
              -Nathan
              • 4. Re: sizing the MediaPlayerSprite
                RyanOConnell Level 2
                I'll just post a working example, and maybe you can build from there  :
                package {
                import flash.display.Sprite;
                import flash.display.StageAlign;
                import flash.display.StageScaleMode;
                import org.osmf.display.MediaPlayerSprite;
                import org.osmf.display.ScaleMode;
                import org.osmf.media.URLResource;
                import org.osmf.net.NetLoader;
                import org.osmf.utils.URL;
                import org.osmf.video.VideoElement;
                     public class SimpleScalingVideoPlayer extends Sprite
                          private static const REMOTE_PROGRESSIVE:String = "http://mediapm.edgesuite.net/strobe/content/test/AFaerysTale_sylviaApostol_640_500_short.f lv";
                      private var _player:VideoElement;
                          public function SimpleScalingVideoPlayer():void
                               _player = new VideoElement(new NetLoader());
                               _player.resource = new URLResource(new URL(REMOTE_PROGRESSIVE));
                               _videoDisplay = new MediaPlayerSprite();
                               _videoDisplay.element = _player;
                               _videoDisplay.width = 100;  //why do you hate me?
                               _videoDisplay.height = 100;  //why do you hate me?
                • 5. Re: sizing the MediaPlayerSprite
                  The difference is SerialElement v/s video element.
                  if i replace the video in your example with a serialElement that has a child video element, the sizing does not work at all.
                  Is that intended?
                  package {
                  import org.osmf.*;
                  import org.osmf.composition.SerialElement;
                       public class Example extends Sprite
                            private static const REMOTE_PROGRESSIVE:String  = "http://mediapm.edgesuite.net/strobe/content/test/AFaerysTale_sylviaApostol_640_500_short.flv";
                            public function Example():void
                                      var serialElement = new SerialElement();
                                      serialElement.addChild(new VideoElement
                                                ( new NetLoader
                                                , new URLResource(new URL(REMOTE_PROGRESSIVE))
                                 _videoDisplay.element = serialElement;
                  • 6. Re: sizing the MediaPlayerSprite
                    Yes, this is how the layout system was designed.  You need to add layout explicitly to each of the children from a composition.  Here is how you would add layout to children from a composition (this specificly gives the video element a scaling layout) :
                    video:VideoElement = new VideoElement( ..  );
                    LayoutUtils.setRelativeLayout(video.metadata, 100, 100);
                    serial:SerialElement = new SerialElement();
                    serial.addChild(video);
