7 Replies Latest reply on Nov 21, 2012 5:39 PM by mmorse22
    actionscript noob
    mmorse22
      I have a flash movie that i want to load 8 movie clips into in succession. In other words I want the first movie clip to play, then be replaced by the next clip and so on until all 8 have played. How would I do this in actionscript? I know virtually nothing about AS so please be specific.
      Thanks much
      -mark
        • 1. Re: actionscript noob
          Where are these movie clips?
          • 2. Re: actionscript noob
            mmorse22 Level 1
            library
            • 3. Re: actionscript noob
              I won't be handing you a solution, so you'll have to take what I offer and do some work to try to get something working.  If you have no background in programming, then you might have a bit of trouble getting thru it and should consider hiring someone.
              Each movieclip (except maybe the last one) will need to be edited so that when it ends it triggers a call to a function in the main movie to load the next movie.  Since you say you don't use actiuonscript, I'll assume your movieclips run along the timeline, so this call will be added to the last frame.  Since that function will be in the main timeline, you would use either _root or _parent to target the function from inside the movieclips.  As in... _parent.loadNext();
              In that main movie function, to load a movie from the library you need to use the attachMovie("linkageID", "clipName", depth) method.  The linkageID is assigned by right clicking the symbol in the library, selecting Properties, selecting the option to Export for Actionscript, and assigning a unique Identifier.  The clipName won't be of much meaning to your goal, so any name will suffice.  If you want to replace a loaded clip with another loaded clip, then you specify it to load into the same depth as the one already loaded.
              In the main timeline you will need to have some kind of reference for the linkageID's of the movieclips set in the order they are to be loaded.  An array will do this just fine.  You will need to have a counter that keeps track of which item is supposed be loaded next, which is incremented each time the loading function executes.
              So your main timeline code would be something like...
              var linkageIDs:Array = new Array("MC1", "MC2", "MC3",....etc);
              var nextMC = 0;
              this.createEmptyMovieClip("mcHolder", this.getNextHighestDepth());
              mcHolder._x = 10; // place it where you want the movieclips to be
              mcHolder._y = 10;
              function loadNext(){
                   mcHolder.attachMovie(linkageIDs[nextMC], "anyname", 1);
                   nextMC += 1;
              loadNext(); // this is to load the first movie clip
              • 4. Re: actionscript noob
                mmorse22 Level 1
                Thanks Ned,
                I don¹t know a thing about AS. Wish I did. Let me see if I understand. On
                the last frame of each clip (except the last one), I add
                _parent.loadNext(); Is that All I add or is there more to it? Does anything
                go into the parentheses?
                On the main movie timeline I add:
                var nextMC = 0;
                mcHolder._y = 10;
                     nextMC += 1;
                Would this go on an actions layer in the main timeline? I realize I have to
                change MC1, MC2 etc to my identifier names. Is ³anyname² a name I assign to
                the empty movie clip?
                Any help you can give to help me understand is greatly appreciated. I know I
                could just create all 8 clips and run them concurently on the timeline
                adding enough empty frames to account for the clip that precedes each of the
                following clips but that would be a messy way of doing it.
                Mark Morse
                Marketing Services
                Sanmina-SCI
                20091 Ellipse
                Foothill Ranch, CA 92610
                949-643-7255 ext 2261
                Reply-To: <clearspace-1816444701-78827-2-2529672@mail.forums.adobe.com>
                Date: Tue, 19 Jan 2010 16:59:20 -0700
                To: Mark Morse <mark.morse@sanmina-sci.com>
                Subject: actionscript noob
                var nextMC = 0;
                mcHolder._y = 10;
                     nextMC += 1;
                • 5. Re: actionscript noob
                  I'll attempt my answers via quoting your response...
                  function(){return A.apply(null,[this].concat($A(arguments)))}
                  That is all, except you probably also want to add a stop(); command just before that line.  Nothing in the parentheses.
                  var nextMC = 0;
                  mcHolder._y = 10;
                       nextMC += 1;
                  Would this go on an actions layer in the main timeline? Sure. I realize I have to
                  the empty movie clip?  the empty movieclip is named mcHolder.  This will act as
                  the home where you load the movieclips.  "anyname" can stay just as it is
                  shown since you have no use for it - it is the name for each movieclip you load.
                  You could load them into 8 consecutive frames, each with a stop() in it, and have
                  each one tell the main timeline to move to the next frame when each finishes...
                  but that's another approach--you might learn more trying what I've offered first.
                  If you're satisfied that your wonderings have been answered, please mark the
                  thread as such.
                  • 6. Re: actionscript noob
                    TheEricBraun Level 1
                    Im not very great with actionscript myself. But if u take these movie clips and place them onto the stage where u would like them to appear. You could just mask them when you would like to appear and then when you are finished with them you could add an unloadMovie(this); Actionscript. or if u would like to use them again a this._visible = false;
                    Probably may wanna use neds suggestions. but worst case senario try this or something? :S
                    • 7. Re: actionscript noob
                      mmorse22 Level 1
                      I did what you stated and this is what happens when I test the movie. I get
                      these messages:
                      Syntax error      mcHolder.attachMovie(linkageIDs[nextMC], "anyname", 1);
                      Syntax error      nextMC += 1;
                      Maybe I¹ll try you other approach. Thanks for all you help.
                      Mark Morse
