0 Replies Latest reply on Jan 19, 2010 2:51 PM by jmurphy67
    [svn:fx-4.0.0] 13638: update to ensure fat-swcs contain a proper packages. dita file.
    jmurphy67 Level 1
      Revision: 13638
      Revision: 13638
      Author:   jimurphy@adobe.com
      Date:     2010-01-19 14:51:32 -0800 (Tue, 19 Jan 2010)
      Log Message:
      update to ensure fat-swcs contain a proper packages.dita file.
      -removed all packages.dita files from all langs where it was checked in
      -at the end of asdoc task we now copy the packages.dita out to the en_US project dir being built.  This is where the fat-swc task will pick up this file and place it in the docs directory of the _rb.swc
      -had to change the order of the build process slightly - old order: ant clean main other.locales doc - new order: ant clean main doc other.locales
      - I removed other.locales from main in the root/build.xml and made it it's own task and also removed the property locales.  so to build other.locales, the doc target needs to run first (will add a depends at some point).
      -in the internal build.xml I have changed to use the new order
      QE notes: make sure FB code hinting still works
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: limitied package testing
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/branches/4.0.0/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/automation/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/datavisualization/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/framework/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/playerglobal/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/spark/build.xml
      Removed Paths:
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airframework/bundles/zh_CN/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/airspark/bundles/zh_CN/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/framework/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/framework/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/framework/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/framework/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/framework/bundles/zh_CN/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/rpc/bundles/zh_CN/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/spark/bundles/de_DE/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/spark/bundles/fr_FR/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/spark/bundles/ja_JP/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/spark/bundles/ru_RU/docs/packages.dita
          flex/sdk/branches/4.0.0/frameworks/projects/spark/bundles/zh_CN/docs/packages.dita
