3 Replies Latest reply on Feb 2, 2010 3:03 AM by tech_savvy
    No audio when exporting to mpeg
    Rickinesc
      Newbie here, on my first project. I have exported it to mpeg and all went well except there is no audio.
      I am using the trial version of Premiere Elements 8 on a PC running Windows 7.
      Any guidance?
        • 1. Re: No audio when exporting to mpeg
          the_wine_snob Level 9
          Welcome to the forum.
          The lack of Audio in an Exported/Shared file is often the lack of the correct setting in the Multiplexing tab. When you go to do the Export, you will choose both Audio & Video in the General tab. Additional settings appear in the Video and the Audio tab. Last, there is the Multiplexing tab, and one must choose one of the other choices, besides None. This is often DV Audio, but there can be others, depending on the other tabs' settings. Check your Multiplexing tab, and let us know what it's set to. That is likely the issue.
          • 2. Re: No audio when exporting to mpeg
            This problem can also be related to your source footage.
            What type of camcorder did your video come from and how did you get it into your computer?
            • 3. Re: No audio when exporting to mpeg
              tech_savvy
              Can you check if the exported file has .mpeg extension or not. There is a slight chance that multiplexing might have failed leading to no audio in the clip.
              If this doesn't help, you can go back to the same export preset, click on Advanced and under the audio tab change audio codec to PCM, save this preset and export again. Now check the exported file, it should be fine
