6 Replies Latest reply on Jan 21, 2010 8:26 AM by msakrejda
    How data change in SQL base can force FLEX app to show pop-up window ?
    Rymasek Level 1
      The problem is this :
      I have SQL database,  to this database data is pushed via .php file which is receiving strings
      using post method. Strings looks like this :
      0.35352&0.234222&status=normal
      0.11352&0.233222&status=normal
      0.55352&0.250222&status=normal
      suddenly we have such a string :
      1.55352&1.250222&status=alarm
      this is send to base as well, but, I would like to show up a pop-up window
      in case of 'status=alarm' string
      My basic idea is to check database in every 5 sec. if there is a change in 'status' column,
      All values should be 'normal', and we need to trigger an alarm if even one shows 'alarm'.
      I have feeling though this is not the best solution, because it's slowing the whole application.
      The question is : how to notify FLEX application that data has changed in database ?
      Thanks for help
