1 Reply Latest reply on Jan 22, 2010 2:41 AM by Willam van Weelden
    Main toolbar button spacing
    Jop Smith Level 1
      I've created custom buttons for my WebHelp skin, but I'd like them to butt up to each other without any space between them. Can anyone tell me if it's possible to remove the spacing between custom buttons on the main toolbar?
      Many thanks
      Jonathan
        • 1. Re: Main toolbar button spacing
          Willam van Weelden Level 5
          The easy answer: no. But there's more to say:
          Not without removing the margins from all of the buttons in your toolbar, and certainly not from the Robo skin editor. In webhelp, your buttons are set in a table and the function writeToolBar() (in whtbar.js) creates that table. I won't recommend changing that, because it has a lot of dependencies and this script is also used to write the minibar (where the browse sequence arrows are located).
          If you want to change some styles, take a look at the function writeStyle(bMiniBar), but everything you change will affect all the buttons. Manually adding the html-code to the string might work, but because the function writetoolbar is used for two toolbars, you need to make sure the html only ends up in one toolbar. I took a peek, but I didn't see anything obvious to do this.
          Greet,
          Willam
          This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
