3 Replies Latest reply on Jan 20, 2010 7:50 AM by kglad
    Preloader: frame 1 stop, on 100% goto frame 2 (AS2)
    fledermaus
      Hello all,
      at first, I thought I could manage this myself searching the forums about "preloader" but none of the solutions seem to work. I think it has to do with the fact that I'm using the FLVPlayer with an external file.
      What am I looking for?
      1. Well, the preload code for frame 1 that makes sure the external F4V (movie.f4v in the same dir) is loaded 100% before it jumps to frame 2 where the movie should start playing...
      2. If possible, a progress bar.
      I'll keep on trying but I'm afraid I need your help since I can't get it working...
      thanks all !
        • 1. Re: Preloader: frame 1 stop, on 100% goto frame 2 (AS2)
          use:
          stop()
          var lo:Object = new Object();
          lo.progress = function(eo:Object):Void {
          // use eo.bytesLoaded and eo.bytesTotal for your progress bar
          if(eo.bytesLoaded==eo.bytesTotal){
          gotoAndStop(2);
          flv.addEventListener("progress", lo);
          flv.load("yourvid.f4v");
          • 2. Re: Preloader: frame 1 stop, on 100% goto frame 2 (AS2)
            fledermaus Level 1
            wow that was fast. I'll try it out right away. You don't have the same code for AS3?
            I would love to compare them since I'm learning AS3 too !
            And the progressbar is just dragging the buffering bar component on it and giving it the same instance name, being... lo then?
            Thanks...
            • 3. Re: Preloader: frame 1 stop, on 100% goto frame 2 (AS2)
              for your progress bar you would using something like:
              stop()
              progressbar.fill._width = progressbar._width*eo.bytesLoaded/eo.bytesTotal;
              gotoAndStop(2);
              and in as3:
              import fl.video.VideoProgressEvent;
              flv.addEventListener(VideoProgressEvent.PROGRESS,progressF);
              flv.load("yourvideo.f4v");
              function progressF(e:VideoProgressEvent){
              progressbar.fill._width = progressbar._width*e.bytesLoaded/e.bytesTotal;
              if(e.bytesLoaded==e.bytesTotal){
              gotoAndStop(2);
