5 Replies Latest reply on Jan 20, 2010 1:40 PM by kglad
    setInterval question
    velocity-vector
      hello --
      i use setInterval that tell an animation to wait 500 ms before going to the next frame...
      setInterval (this, "nextFrame", 500);
      clearInterval();
      now i want it to wait 500 ms before going to the next snippet of code. how do i do this?
      I tried this method but to no avail
                function waitHalfSecond () {
                 clearInterval(myInterval);
                 myInterval = setInterval(waitHalfSecond, 500);
      /* OLD CODE */
      stop();
      attachMovie("bottom_btn_mc","bottom_btn_mc", 7,{_x:0, _y:0});
      bottom_btn_mc._alpha=0;
      bottom_btn_mc.onEnterFrame = function () {
      this._alpha += 14;
      if (this._alpha >= 90) {
        delete this.onEnterFrame;
      clearInterval();
      /* NEW CODE */
      stop();
      this._alpha += 14;
      /*// setInterval code here, wait 500 ms, then execute next line //*/
        attachMovie("spread_home_txt","spread_home_txt",8,{_x:4, _y:22});
        spread_home_txt._alpha=0;
        spread_home_txt.onEnterFrame = function () {
          this._alpha += 14;
        • 1. Re: setInterval question
          what exactly are you trying to do?
          • 2. Re: setInterval question
            velocity-vector Level 1
            instead of going to the next frame and playing the code, i want to incorporate all the code in just frame 1.
            i need to wait a half second before loading *spread_home_txt*, instead of just depending on the onEnterFrame after the *bottom_btn_mc* loads.
            hope that makes sense. thanks > mark
            /* code in frame 1 */
            stop();
            this._alpha += 14;
            setInterval (this, "nextFrame", 500); // go to the next frame after a half-second
            clearInterval();
            /* code in frame 2 */
            stop();
            this._alpha += 14;
            • 3. Re: setInterval question
              all code whose execution you want to delay, put in a function.  call that function using setTimeout(), if the code need only execute once.  use setInterva() is you want the code to execute repeatedly.
              p.s.  to clear a setInterval(), you must assign a variable to the setInterval and use that variable in your clearInterval() function:
              codeI=setInterval(codeF,234);
              // clearInterval(codeI);
              • 4. Re: setInterval question
                thanks --
                this is how i applied the setInterval (works fine)...
                     this._alpha += 14;
                function waitHalfASecond () {
                          this._alpha += 14;
                clearInterval(timerInterval);
                timerInterval = setInterval(this, "waitHalfASecond", 500);
                • 5. Re: setInterval question
                  you're welcome.
