5 Replies Latest reply on Jan 20, 2010 3:07 PM by ~graffiti
    Saving PDF as jpeg
    Ulstad
      Adobe updated my reader to 9. In my previous version, I could save a PDF to a jpeg. This was very usefull to me with several programs.
      The new version 9 does not appear to have that functionality any longer.
      Questions
      Can the function be found in version 9?
      If not, where could I find, download and install a previous version of reader that was so usefull for me?
        • 1. Re: Saving PDF as jpeg
          Bernd Alheit Adobe Community Professional & MVP
          Yes, thisi function is available in Adobe Acrobat. The function was never availbale in Adobe Reader.
          • 2. Re: Saving PDF as jpeg
            ~graffiti Adobe Community Professional & MVP
            Sounds like you went from Acrobat to Reader (which isn't an upgrade but a downgrade). Reader can't convert PDF's to .jpg. It's basically an application to view and print PDF's.
            If Acrobat is gone from your system, you will want to uninstall Reader then reinstall Acrobat being sure not to have both installed on your system (having both can cause other issues).
            • 3. Re: Saving PDF as jpeg
              Ulstad Level 1
              Thanks.
              I also have Acrobat. version 7. I opened it up and was able to save my PDf just as I wanted.
              Thanks again.
              Steven Ulstad AIA ASLA
              [Signature deleted by host]
              • 4. Re: Saving PDF as jpeg
                Ulstad Level 1
                I do have both, the reader was just automatically updated by adobe. But I also have Acrobat 7.
                I opened it up and was able to save the PDF just as I wanted.
                Thanks again
                • 5. Re: Saving PDF as jpeg
                  You are welcome.
                  Keep in mind that having both installed is not recommended nor supported by Adobe. Some people can get lucky and won't suffer any ill effects with that configuration but others can suffer unfixable issues.
