2 Replies Latest reply on Nov 28, 2007 2:35 PM by Newsgroup_User
    Flex Builder bug - .svn folders are copied to the output folder
    Raanan_Zvi
      I'm using the Subersion version control system (Using Tortoise SVN as the client) to control my Flex project code.
      I added to the subversion repository my Flex project (all folders except the bin folder). When Flex compiler builds the project, it copies the "html-template" folder to the bin directory, it also copies the ".svn" folders that the subversion system puts in the "html-template" folder. This also happens if I select to "copy non-embedded files to output directory" option in the Flex Compiler properties of the project. The compiler copies all the ".svn" folders he can find in the source folder (recursively).
      As I see it, this is a bug because the ".svn" folders are hidden, therefor they should not be copied.
      Maybe it is a missing feature in the flex compiler properties, that indicates to the Flex compiler not to copy hidden folders to the output directory.
