3 Replies Latest reply on Jan 20, 2010 1:06 PM by the_wine_snob
    Re-rendering
    trickyrick583
      Hi guy and gals
      I have a a few avi's (short clips) that i want to use Premiere Elements go put together into one clip.  Is there any way to do that and save to avi without re-rendering
        • 1. Re: Re-rendering
          the_wine_snob Level 9
          So much will depend on the full specs. of your AVI files. AVI is but a "wrapper," and much can be inside that. This ARTICLE will give you some background, and tips for peeking inside the wrapper.
          If you Export/Share a DV-AVI to that format, the tiny bit of re-compression in Transcode will not be noticed.
          If you want a totally lossless format/CODEC, look into the Lagarith Lossless.
          PS - welcome to the forum!
          • 2. Re: Re-rendering
            trickyrick583 Level 1
            Thanks for the reply I read both links
            Im going to try the lossless codec
            Thanks again
            Rick
            • 3. Re: Re-rendering
              Once you have downloaded and installed the Lagarith Lossless CODEC, it should appear in the list of AVI (beyond the DV flavors, and others) in the Compression drop-down (the one that usually defaults to Cinepak by Radius). I'd show it to you, but I only have PrE 4, and PrE 8 has moved some things around. Still, with AVI chosen, the Compression Type drop-down should then show Lagarity. Be sure to reboot, after you install it.
