3 Replies Latest reply on Jan 21, 2010 7:59 AM by JoyceEvans
    Dropdown menu help
      I am updating my website, and created a dropdown menu using fireworks. (later I installed it into dreamweaver, but I'm not sure that that makes any difference) The problem I am having is that each item in the dropdown menu opens in a new tab when I click it, and I want it to stay in the same window. My site is here:  www.nicolemn.com
      Any suggestions on how I can fix this?
      Thank you.
        • 1. Re: Dropdown menu help
          pixlor Level 4
          That code is awful! How in the world do you expect to maintain this code with names like these? Using Fireworks code for a live site (rather than building in Dreamweaver, for example) is just asking for trouble.
          Here's your menu code:
          <a id="MMMenu0120182959_0_Item_0" class="MMMIFVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0');" target="Home" href="http://www.nicolemn.com/home.html">  Home </a>
          <a id="MMMenu0120182959_0_Item_1" class="MMMIVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0','1');" target="Photography" href="http://www.nicolemn.com/photography.html"></a>
          <a id="MMMenu0120182959_0_Item_2" class="MMMIVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0');" target="Design" href="http://www.nicolemn.com/design.html"> Design </a>
          <a id="MMMenu0120182959_0_Item_3" class="MMMIVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0');" target="About" href="http://www.nicolemn.com/about.html"> About </a>
          <a id="MMMenu0120182959_0_Item_4" class="MMMIVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0');" target="Contact" href="http://www.nicolemn.com/contact.html"> Contact </a>
          <a id="MMMenu0120182959_0_Item_5" class="MMMIVStyleMMMenu0120182959_0" onmouseover="MM_menuOverMenuItem('MMMenu0120182959_0');" target="Link" href="http://www.nicolemn.com/links.html"> Links </a>
          Answer to your question:
          Your trouble is with these bits in the code above:
          The target attribute has to do with what window the link opens in. You have each link open in a new named window (not a standard thing to do). See this description: http://www.developingwebs.net/html/targetattribute.php You need to remove the target attributes in the section of code I quoted and anywhere else you're using them inappropriately.
          Optional stuff:
          You might also consider whether or not each link needs its own id and if a more memorable class name ("mainnav" perhaps?) might be better than "MMMIFVStyleMMMenu0120182959_0."
          I'm not a fan of your menu only showing up if the user mouses over your logo. What if the user never does that? You're pinning your hopes and expectations on a random user behavior. That's poor usability. Navigation should be clear, not hidden. Also, users dislike splash pages, as it's extra time needed to load a page that has no content on it. It's a barrier to content and the Web is all about access to content.
          • 2. Re: Dropdown menu help
            Jim_Babbage Level 4
            Save yourself a lot of grief and do NOT use that menu system. Trust me, you are not saving yourself any time. They are not working properly in CS4 and are a PITA to maintain after they're built.
            Jim Babbage
            • 3. Re: Dropdown menu help
              JoyceEvans Level 3
              I have to add my 2 cents as well...please don't use FW menus for final site:-) Great
              for comps only. Good CSS menus are easy to maintain and search engine friendly. As a busy designer I love the Project Seven menus and great su[port (http://projectseven.com) or build your own http://www.htmldog.com/articles/suckerfish/dropdowns/
