1 Reply Latest reply on Jan 21, 2010 7:19 AM by iamfuric
    Locales
    rabinprithvi Level 2
      I came across a nice articles here for locales.
      http://labs.adobe.com/wiki/index.php/Flex_3:Feature_Introductions:_Runtime_Localization
      After implementing the locales, I want to customize it further.
      If I want to change some values in .properties file, I have to compile it again .
      Is it possible to load the .properties file like xml or text file and get the values directly.
        • 1. Re: Locales
          iamfuric Level 2
          This nice article states that :
          the MXML compiler autogenerates a subclass of ResourceBundle with a content Object containing the key/value pairs for those resources.
          It means you can't achieve what you want with built in  resource localization support.
          But, yes, you can  load properties  file by yourself  -you will have to parse it by yourself into Dictionary object.
          In this case I suggest to remove each
          <mx:Metadata>
                  [ResourceBundle("myResources")]
              </mx:Metadata>
          so Flex will not autogenerate his stuff and your swf/swc won't contain the files your  application doesn't use...
