6 Replies Latest reply on Jan 22, 2010 1:58 PM by rgadiparthi
    problem with hbox
    venkateshk Level 1
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
           creationComplete="cc()">
          <mx:Script>
              <![CDATA[
                  import mx.containers.Box;
                  private var box:Box;
                  private function cc():void{
                       for(var i:int=0;i<hb1.width;i=i+15)
                          box = new Box();
                          box.width=15;
                          box.height = hb1.height-2;
                          box.setStyle("borderStyle","solid");
                          hb1.addChild(box);
                  //can1.getchi
          </mx:Script>
          <mx:HBox id="hb1" width="100" height="50" x="40" y="40" backgroundColor="#999999"
              minHeight="0" minWidth="0" borderStyle="solid" horizontalGap="0"
              paddingLeft="0" paddingRight="0" paddingTop="0" paddingBottom="0"/>
      </mx:Application>
      it's not filluping the hbox with boxes correctly
      I want the boxes to be fit in the hbox
      please............. help me
        • 1. Re: problem with hbox
          Sebastien V. Level 3
          What's the result and what do you expect it to be?
          • 2. Re: problem with hbox
            venkateshk Level 1
            The result is fill up the boxes but they are not fit in the hbox
            I want a hbox in that i want to fill boxes with 15 width each side by side
            • 3. Re: problem with hbox
              I think I see what you're trying to do, but I still can't understand what the problem is.
              What do you mean exactly by 'the boxes are not fit in the hbox" ?
              Are there margin on the left, right, top or bottom? Are the boxes completely outside of your HBox? Are there margin between the boxes?
              • 4. Re: problem with hbox
                NFRIACowboy
                Well, as we use to say "Keep it Simple"
                instead of doing calculations on the for cycle that is not good for performance do it before see my example:
                            var count:int = Math.floor(hb1.width / 15);
                                 for(var i:int=0;i<count;i++)
                                    box = new Box();
                                    box.width=15;
                                    hb1.addChild(box);
                I guess that is easy to understand where the problem was
                • 5. Re: problem with hbox
                  venkateshk Level 1
                  it's not coming with ur suggestion but when i remove borderStyle property of HBox it's working fine
                  but i don't understand what's going on here
                  • 6. Re: problem with hbox
                    rgadiparthi Level 2
                    use canvas instead of Hbox, it will work.
                    or add canvas inside u r Hbox.
