6 Replies Latest reply on Jan 22, 2010 11:37 AM by Peter deHaan
    Deleting Flex projects problem
    SiHoop Level 1
      I've experienced the following problem several times and want to document it on this board.
      While working on an mxml file I press 'delete' multiple times. The result is that several project folders (including the one I'm currently working on) and their contents are permanently deleted from Flex and my hard drive.
      Normally when a project is deleted a dialog box appears "Are you sure you want to delete project 'xxx'?" In the case I'm describing the warning dialog does not appear. Needless to say this is a devastating bug. I am meticulous about backing up my projects, but it is still a problem when it occurs.
      I'm sure that other people must have experienced this bug. Is there any way to avoid it in Flex 3 and has anything been done about it in Flex 4?
