2 Replies Latest reply on Jan 28, 2010 12:01 PM by Cloakedbolt
    Print output for PDF inverted.
    Cloakedbolt
      Hello,
      I am having an issue with Adobe Reader 9.0.
      When I print my PDF files using Grayscale they all output with black background and white text. My PDF documents are not like this at all, they use a white background and black text. This only happens with PDF files.
      The printer is a HP Laserjet 3600.
        • 1. Re: Print output for PDF inverted.
          Cloakedbolt Level 1
          Still unable to get this working correctly,
          Is there a setting on the printer itself that must be configured? Or is it on the printer properties in Windows XP?
          • 2. Re: Print output for PDF inverted.
            Cloakedbolt Level 1
            Just replying to post the solution, so if someone is looking for the solution, it will be there.
            The issue was my printer driver. Apparently it's a bug with the latest drivers, that glitched the grayscale function on the 3600. Unsure why it only affected PDF files though.
            Anyway, I just deleted the printer and I deleted the driver from the server properties (contextual menu in Print & Faxes, Driver tab). Then I reinstalled it using the older drivers.
