0 Replies Latest reply on Jan 21, 2010 12:26 PM by HansMuller
    [svn:fx-trunk] 13693: Initial version of the mirroring layout code.
    HansMuller
      Revision: 13693
      Revision: 13693
      Author:   hmuller@adobe.com
      Date:     2010-01-21 12:25:54 -0800 (Thu, 21 Jan 2010)
      Log Message:
      Initial version of the mirroring layout code.  Only Spark is supported.  API revisions for this feature are very likely to follow.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Evtim
      Tests run: All Mustella tests pass
      Is noteworthy for integration: yes
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultItemRenderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/utils/BitmapUtil.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ILayoutDirection.as
