0 Replies Latest reply on Jan 21, 2010 3:28 PM by jmurphy67
    [svn:fx-trunk] 13699: -update textLayout, osmf, and flash-integration
    jmurphy67 Level 1
      Revision: 13699
      Revision: 13699
      Author:   jimurphy@adobe.com
      Date:     2010-01-21 15:28:17 -0800 (Thu, 21 Jan 2010)
      Log Message:
      -to build proper _rb swcs with the recent localized properties that have been checked in for each project
      -to build proper fat-swcs with the recent localized xml that have been checked in for each project
      updated the spark/build.xml to pint the properties files under textLayout and osmf
      removed files from package that were not required: build.xml, build.properties, sparkskins/assets folder.
      QE notes:
      Doc notes:
      Bugs: sdk-25171
      Reviewer:
      Tests run:
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-25171
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/projects/datavisualization/build.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
          flex/sdk/trunk/frameworks/projects/osmf/build.xml
          flex/sdk/trunk/frameworks/projects/rpc/build.xml
          flex/sdk/trunk/frameworks/projects/spark/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/osmf/bundles/da_DK/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/da_DK/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/de_DE/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/es_ES/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/es_ES/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/fi_FI/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/fi_FI/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/fr_FR/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/it_IT/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/it_IT/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/ja_JP/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/ko_KR/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/ko_KR/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/nb_NO/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/nb_NO/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/nl_NL/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/nl_NL/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/pt_BR/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/pt_BR/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/ru_RU/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/sv_SE/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/sv_SE/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/zh_CN/osmf.properties
          flex/sdk/trunk/frameworks/projects/osmf/bundles/zh_TW/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/zh_TW/osmf.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/da_DK/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/da_DK/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/de_DE/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/es_ES/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/es_ES/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/fi_FI/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/fi_FI/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/fr_FR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/it_IT/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/it_IT/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ja_JP/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ko_KR/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ko_KR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/nb_NO/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/nb_NO/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/nl_NL/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/nl_NL/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/pt_BR/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/pt_BR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/ru_RU/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/sv_SE/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/sv_SE/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/zh_CN/textLayout.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/zh_TW/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/zh_TW/textLayout.properties
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/datavisualization/manifest.xml
          flex/sdk/trunk/frameworks/projects/spark/bundles/da_DK/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/da_DK/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/de_DE/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/de_DE/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/es_ES/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/es_ES/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fi_FI/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fi_FI/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fr_FR/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/fr_FR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/it_IT/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/it_IT/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ja_JP/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ja_JP/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ko_KR/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ko_KR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nb_NO/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nb_NO/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nl_NL/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/nl_NL/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/pt_BR/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/pt_BR/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ru_RU/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/ru_RU/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/sv_SE/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/sv_SE/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_CN/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_CN/textLayout.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_TW/osmf.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/zh_TW/textLayout.properties
