5 Replies Latest reply on Jan 22, 2010 8:59 AM by Gregory Lafrance
    From to To highlighting
    venkateshk Level 1
      Please..... help me
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
           backgroundColor="silver" creationComplete="cc()">
      <mx:Script>
              <![CDATA[
      private function cc():void{
                       for(var i:int=25,j:int=1;i<=hb1.width;i=i+25,j++)
                          box = new Box();
                          box.width=25;
                          box.height = hb1.height;
                          box.setStyle("borderStyle","solid");
                          box.setStyle("borderColor","black");
                          box.setStyle("verticalAlign","middle");
                          box.setStyle("horizontalAlign","center");
                          box.id = "A"+j;
                          lab = new Label();
                          lab.text = "A"+j;
                          box.addChild(lab);
                          box.addEventListener(MouseEvent.CLICK,onMouseClick);
                          hb1.addChild(box);
      private function onMouseClick(event:MouseEvent):void
                      if(event.currentTarget.getStyle("backgroundColor") != 0xFF0000){
                          event.currentTarget.setStyle("backgroundColor", 0xFF0000);
                        }else{
                          event.currentTarget.setStyle("backgroundColor", null);
      </mx:Script>
      <mx:HBox id="hb1" width="1000" height="70" x="10" y="40" horizontalGap="0"/>
      <mx:HBox x="200" y="500" paddingBottom="0" paddingTop="0">
              <mx:Label text="From :" paddingTop="0" fontWeight="bold" fontSize="20"/>
              <mx:TextInput width="35" id="tiFrom"/>
              <mx:Spacer width="18"/>
              <mx:Label text="To :" fontWeight="bold" fontSize="20"/>
              <mx:TextInput width="35" id="tiTo"/>
              <mx:Button label="Proceed"/>
          </mx:HBox>
      </mx:Application>
      The above application gives HBox filled with multiple Boxes and each box has a label inside it i.e A1,A2,................A40
      and when i click on particular box it is highlighting with color if it is not filled with color it's well
      and now i want that From to To highlighting
      i.e if i give A5 in tiFrom and A10 in tiTo and clicking on Proceed button then I want that the boxes A5,A6,A7,A8,A9,A10 to be highlighted
        • 1. Re: From to To highlighting
          Gregory Lafrance Level 6
          This code solves your problem:
          <mx:Script>
                  <![CDATA[
                    import mx.controls.Label;
                    import mx.containers.Box;
                              var box:Box = new Box();
                              box.width=25;
                              box.id = "A"+j;
                              var lab:Label = new Label();
                              lab.text = "A"+j;
                              box.addChild(lab);
                              hb1.addChild(box);
                            }else{
          private function changeOneBG(disObj:Object):void{
                      private function setHighlightRange():void{
                        if(tiFrom.text!="" && tiTo.text!=""){
                          var start:uint = uint(tiFrom.text.substring(tiFrom.text.search(/\d+/)));
                          var end:uint = uint(tiTo.text.substring(tiTo.text.search(/\d+/)));
                          for each(var box:Box in hb1.getChildren()){
                            var boxLbl:String = "";
                            for each(var obj:Object in box.getChildren()){
                              if(obj is Label){
                                boxLbl = obj.text;
                                var num:uint = uint(boxLbl.substring(boxLbl.search(/\d+/)));
                                if(num >= start && num <= end){
                                  box.setStyle("backgroundColor", 0xFF0000);
                                }else{
                                  box.setStyle("backgroundColor", null);
          </mx:Script>
                  <mx:Button label="Proceed" click="setHighlightRange();"/>
              </mx:HBox>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: From to To highlighting
            venkateshk Level 1
            ThankQ very much
            May I keep in touch with u?
            • 3. Re: From to To highlighting
              venkateshk Level 1
              It's working
              but even i give just 1 to 10 it's taking ok
              what I want is that
              earlier I have one HBox in that i have multiple boxes ok fine
              if I have multiple HBoxes named as A,B,C  etc all contain multiple Boxes
              I will add one combo box in that I have A,B,C
              then I can select anyone of the A,B,C from combo box and i can enter the from,to values then corresponding boxes need to be fill in that selected HBox
                      <mx:ComboBox dataProvider="{['A','B','C']}"/>
                  </mx:HBox>
              Please help me
              • 4. Re: From to To highlighting
                venkateshk Level 1
                it's working fine
                but at second time when i give another values previous highlighted boxes are unhighlighted and later given box values are highlighted
                i need the previous highlighted boxes also to be highlighted when i give another new values
                please................ give the solution
                • 5. Re: From to To highlighting
                  I responded to your other post to solve the problem of the previously highlighted boxes becoming unhighlighted.
                  I'm available for contract work. For non-paying questions, its best to post to this forum as you'll get more responses, usually.
