0 Replies Latest reply on Jan 22, 2010 9:44 AM by Gaurav J
    [svn:fx-4.0.0] 13717: SDK 4 BOM Cleanup: SDK contains extra bundles folders for automation projects.
    Gaurav J Adobe Employee
      Revision: 13717
      Revision: 13717
      Author:   gauravj@adobe.com
      Date:     2010-01-22 09:44:20 -0800 (Fri, 22 Jan 2010)
      Log Message:
      Cleaned up the build.xml files. I did not delete the bundles folder from svn but instead I excluded them from the packaged zip file.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-25207
      Reviewed By:
      Tests run:
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25207
      Modified Paths:
          flex/sdk/branches/4.0.0/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/automation_air/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/automation_dmv/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/automation_flashflexkit/build.xml
          flex/sdk/branches/4.0.0/frameworks/projects/automation_spark/build.xml
